Laminate To Tile Transition - Flooring - DIY Chatroom Home Improvement Forum
Old 08-03-2015, 07:30 PM   #1
In a little over my head
Rewards Points: 710
laminate to tile transition
Hi all. I just finished installing a laminate floor in a kitchen. The rest of the house is hardwood floors. With the underlayment, pad, and the thickness of the laminate, I have a 3/4" difference in height. One 32" cased opening (no door) and one 9' stretch where we removed a wall.
All the pre-made threshold/transitions I could find will allow a 1/2" difference. I've bought a piece of 5/4" oak and am going to make what I need on the table saw. It'll look and work great. But, I have to wonder how a professional installer would solve it.
ratherbefishing is offline   Reply With Quote
Old 08-03-2015, 11:33 PM   #2
Rewards Points: 5,348
Andersen makes a thick transition piece that you use on their patio doors. If that doesn't work, make one.
Take a 3/4 piece of stock and cut a 12 degree bevel on one face. Leave 1/4" on the low side so it doesn't split or crack.
I did it for a ceramic to hardwood floor transition with 4/4 oak. It was 82" long. Had to sand off some burn marks due to the length, but worked out fine.
If this isn't what you can do, try a woodworking shop.
Ron
B. Franklin 1759
Wood to travertine tile transition Troy32 Flooring 3 07-22-2013 08:46 AM
Temporary transition - tile to vinyl Bob... Tiling, ceramics, marble 5 05-20-2013 10:29 PM
Transition from hardwood to tile Trustmemalawyer Flooring 5 07-27-2011 11:09 PM
Bathroom tile installation demolition Kitchen & Bath Remodeling 4 04-10-2011 08:48 PM
How to transition from lower tile to higher tile? PatrickGSR94 Tiling, ceramics, marble 2 04-07-2011 07:21 PM
