Laminate On Stairs - Flooring - DIY Chatroom Home Improvement Forum
Old 10-21-2013, 03:20 PM   #1
Rewards Points: 51
Laminate on Stairs
We are going to try to remove our carpet on our stairs and install laminate. I have seen a couple of good videos on how-to. They involve cutting the overhang off of the stair tread or adding a piece of wood under the overhang to get rid of the overhang. This would reduce the depth of the stair tread from 11" to 9". Just wondering if anyone had done this and if this sounds like it would be an ok thing to do (reduce the depth of tread).
abacker is offline   Reply With Quote
Old 10-21-2013, 04:51 PM   #2
Rewards Points: 18,384
Very bad idea.
Both using laminate and cutting off the nosing.
The minimum tread length by code is 11".
Laminate can not be glued or nailed down, it needs to float.
Laminate is also slippery.
The cheap nosing they sell for laminate is just compressed paper with a thin piece of what looks like shelf paper over it that wears through and peels off.
Stick with real wood treads!
rusty baker (10-21-2013)
Old 10-21-2013, 04:57 PM   #3
Pro Flooring Installer
rusty baker's Avatar
Rewards Points: 400
Originally Posted by joecaption View Post
Very bad idea.
I agree 100%.
The ads in my post are there without my permission. I do not endorse any of the products.
Semi-Retired Installer
Installing since 1973
Old 10-21-2013, 05:54 PM   #4
Rewards Points: 51
So that would mean a pro install, correct? And they could work with that overhang?
Laminate at base of stairs daisychain Flooring 0 11-29-2010 02:22 PM
Counter top plastic laminate Gerry Kiernan Interior Decorating 4 10-13-2008 11:44 AM
Putting laminate floors upstairs..what should I do with my stairs genyaf Flooring 4 01-02-2008 11:52 PM
HELP - laminate on stairs mf915 Flooring 6 07-11-2007 11:12 PM
