Laminate (Pergo) Install Around Pole - Flooring - DIY Chatroom Home Improvement Forum
Like Tree4Likes
  • 2 Post By Nealtw
  • 1 Post By Nealtw
  • 1 Post By alexanderbright
Old 02-21-2019, 11:19 AM   #1
Rewards Points: 64
Do I need to leave the required space around poles in the center of the room? or is it just around the perimeter?
If I do need to leave space, any suggestions on how to cover the gap?
alexanderbright is offline   Reply With Quote
Old 02-21-2019, 11:24 AM   #2
retired framer
Rewards Points: 20,580
Re: Laminate (Pergo) Install Around Pole
https://www.homedepot.com/p/Pole-Wra...CB40/100274613
Do not use flat bottom gables with scissor trusses.
Nealtw is offline   Reply With Quote
Old 02-21-2019, 11:52 AM   #3
Rewards Points: 64
Awesome, that looks great! And I'm guessing yes on leaving the space for expansion?
Old 02-21-2019, 11:56 AM   #4
retired framer
Yes leave a gap. .Either that or you make you own, I have done them out of 2 layers of 1x? one smaller than the other with routered edges and the then installed them with offset joins.
Old 02-21-2019, 11:59 AM   #5
rooster4321's Avatar
Rewards Points: 4
You might consider a bead of caulk
Sent from my KYOCERA-E6560 using Tapatalk
rooster4321 is offline   Reply With Quote
Old 02-21-2019, 12:50 PM   #6
Rewards Points: 64
Thanks, was planning on putting in the foam backer rod and then caulking over it.
Old 02-21-2019, 06:07 PM   #7
Contractor/Engineer
Rewards Points: 1,124
Cover the gap by boxing the column with 1X4. Trim the bottom with the same baseboard as around the room. Far more elegant than leaving a painted lally column. IMO.
Domo is offline   Reply With Quote
Old 02-21-2019, 06:32 PM   #8
Property Mgt/Maint
Rewards Points: 6,546
Research Split Escutcheon. It wouldn't be as decorative as the split oak trim, but you might like the price better.
https://www.bing.com/images/search?q...late&FORM=IGRE
[political signature removed]
Yodaman is offline   Reply With Quote
Old 02-22-2019, 04:31 PM   #9
Rewards Points: 64
Thanks! I'm going to go with the wood trim, but that's a nice and cheap alternative.
The beams had a box made out of 1x4's around it that looked alright, but I had to take it off to get the laminate under because there was carpet installed underneath it. My plan is to paint the poles white and put the trim down for now, see how I like it. If I don't, then I'll replace the 1x4's and will have wasted a little time and thought on fitting around the poles
Old 02-22-2019, 04:34 PM   #10
retired framer
And who doesn't need a stripper pole in the basement.
Yodaman likes this.
Old 02-22-2019, 07:51 PM   #11
Rewards Points: 64
And I'm fortunate to have 2.
Nealtw likes this.
Install laminate over laminate / concrete smiller303 Flooring 2 09-13-2017 04:05 AM
a few laminate floor install questions mcvane Flooring 5 11-21-2014 01:34 PM
Laminate Stairs and Floor install MLayden Flooring 1 09-06-2012 06:29 PM
Poor Laminate Install - OK to Negotiate Bill After Work Complete? ralph99 Off Topic 13 10-21-2010 07:28 PM
HOW MUCH?? To have utility company install new pole? ehoez Electrical 3 06-26-2008 10:18 AM
