Laminate Over Uneven Basement Floor - Flooring - DIY Chatroom Home Improvement Forum
Old 11-09-2014, 11:00 AM   #1
Rewards Points: 16
Laminate over uneven basement floor
Hi All,
I'm renovating my basement, and this is the first time that I've ever done any flooring.
I have a laminate that I am planning to lay down over a subfloor of the dimpled foundation wrap used for waterproofing.
The pad in my basement is not as level as it could be. I have already used leveling compound, quite a bit of it, actually, but it's a fairly large and open area and even in doing that I was unable to get a perfect level throughout.
What can I do to bridge the remaining low points? I've read about using asphalt shingles for shimming, and wonder if that could be an option? If so, what is my best method? I was planning on laying the floor right over the wrap, but is it feasible to use shingles over the membrane, to level a layer of osb and then the floor over that? Headroom is an issue, so definitely looking at as thin of a solution as possible.
Any help is greatly appreciated.
Mister_E is offline   Reply With Quote
Old 11-09-2014, 01:49 PM   #2
Tileguy
JazMan's Avatar
Rewards Points: 780
You need to make the floor flat before installing the membrane. A #50 of self leveling does about 50 sq. ft. @ ⅛" thick. You need lots of bags for a large area.
If you have only a few high spots, grind them down first. Fill all the low spots till all is flat. Self leveling needs help to flow and lots of planning to get it right. No shims or OSB. OSB isn't gonna make the floor flat, just higher.
Jaz
MARBLE from ITALY & GREECE -PERLATO-PERLATINO-BOTTICINO-THASSOS-SIVEC-VOLAKAS-CALACATTA- NAXOS-Slabs-Tiles-Custom containers shipped to you - [email protected]
Old 11-09-2014, 02:03 PM   #3
Pro Flooring Installer
rusty baker's Avatar
Rewards Points: 400
At the worst, laminate will separate on an uneven floor and the best you could hope would be that it would be very noisy when you walk on it.
The ads in my post are there without my permission. I do not endorse any of the products.
Semi-Retired Installer
Installing since 1973
Old 11-09-2014, 02:17 PM   #4
Rewards Points: 528
Why laminate in a basement?
framer52 is offline   Reply With Quote
Old 11-09-2014, 03:11 PM   #5
Rewards Points: 400
I agree, not a good idea, but we don't seem to have much luck talking people out of it.
Old 11-09-2014, 04:59 PM   #6
Rewards Points: 528
i HAVE MADE A LOT OF MONEY THE LAST TWO YEARS REPLACING IT IN BASEMENTS.
\I guess we should encourage them to do it?
Old 11-09-2014, 05:33 PM   #7
Rewards Points: 109
Agree that laminate in a basement is a bad idea. Basements are subject to moisture for a number of reasons and laminate is subject to damage from moisture. The joints rippling, or just plain humps.
MaineLL is offline   Reply With Quote
Old 11-09-2014, 05:34 PM   #8
Rewards Points: 16
What is a better option. I have a lot of laminate available to me.
I'm not that big on tiling.
Old 11-09-2014, 09:50 PM   #9
Rewards Points: 528
Basements I like a product called allure.
www.homedepot.com/c/SPC_BRD_FL_TrafficMaster
Go to the link and look for allure.
Old 11-09-2014, 10:03 PM   #10
Rewards Points: 400
Not me. Read all the complaints on this forum about Allure.
Old 11-10-2014, 08:00 AM   #11
Rewards Points: 109
Allure is a much better choice than laminate in a basement, though. As a landlord, Allure is a great product. Reasonably priced, easy installation by the DIY-re, looks good, is easily replaced and/or repaired if it is damaged and is more pet proof than most other floorings of choice. I've laid in in several apartments in kitchens and baths with no problems. Have also replaced several sections that were damaged with no problems.
In a basement the Ultra is a better choice than the grip strip because excessive, persistent moisture through the floor can cause failure in the grip strip.
Old 11-10-2014, 09:26 AM   #12
agreed on the Allure product.
bps23 is offline   Reply With Quote
Old 11-10-2014, 11:37 AM   #13
Tileguy
Bud Cline's Avatar
Rewards Points: 558
The subfloor (in this case the concrete) doesn't have to be "level", it does however have to be "plane". There's a difference. OSB over concrete isn't the answer, don't even go there. The shingles is also a bad idea, what will hold them in place? Laminate floors are floating floors and any up and down movement (from an out-of-plane subfloor) will cause the floor to self-destruct at the seams, if the moisture doesn't get to it first.
XXX
Uneven concrete basement floor problem Novice_Minty Flooring 8 02-19-2013 12:21 AM
Install Partition Stud Track over Laminate Floor Andy21 Building & Construction 7 06-24-2011 03:00 PM
Laminate floor in basement questions vesh1717 Flooring 2 11-26-2010 01:06 PM
Uneven Floor Edge for Laminate Flooring sgk Flooring 1 06-21-2010 07:23 PM
Wet basement, uneven floor - what's the best flooring? pepsigirl Flooring 1 05-16-2009 08:36 PM
