Laminate Over Tile - Flooring - DIY Chatroom Home Improvement Forum
Old 03-15-2016, 05:14 PM   #1
Rewards Points: 6
Laminate over tile
Hi all,
Im installing 10MM laminate with a 2MM attached pad over my existing tile. I'm currently removing all the baseboard that was tiled up against. This leaves a gap between the tile and drywall, which is about 1/2"wide x 3x8" deep down to the concrete foundation.
Should i fill it in with anything before laying my laminate? The below tile grade portion
It would seem like a future ant highway if i leave it hollow.
Also, is there any concern with continuing laminate between 3 rooms without using t-moulding between the spaces? total length between the 3 spaces 52'x14' across at its widest point?
Any suggestions would be appreciated.
Laminate over tile-1458079821500717494201.jpg   Laminate over tile-1458079865825-1863228201.jpg
BrianLVNV is offline   Reply With Quote
Old 03-15-2016, 06:09 PM   #2
Rewards Points: 6
Re: Laminate over tile
I'm considering doing t-mouldings between the Family room/kitchen and Family room/entry Hall
Old 03-15-2016, 06:21 PM   #3
Retired Moderator
Rewards Points: 7,174
The gap? Fill with caulk if you wish----no harm done.
The manufacturer will have a spec on how long of a run is safe---I've done 35 feet without an issue--but I have also seen buckling when the floor did not have proper expansion space---I have not done a lot of laminate---but I do leave a good sized gap under the base and shoe -(1/2" to 3/4") and under cut door jambs so the goods don't bind up at a doorway.
Tile over laminate countertop MrsEmPeel Remodeling 10 07-15-2014 09:27 PM
Tile on Laminate onthebrinck Remodeling 2 10-26-2012 10:26 AM
Tile over laminate backsplash? Atlantis Building & Construction 5 08-03-2012 08:06 AM
Basement Bar Flooring - Laminate & Tile Setzer1994 Flooring 0 04-18-2012 01:28 PM
Counter top plastic laminate Gerry Kiernan Interior Decorating 4 10-13-2008 10:44 AM
