Laminate Over Ceramic? - Flooring - DIY Chatroom Home Improvement Forum
Old 03-03-2018, 05:36 PM   #1
PPBART's Avatar
Rewards Points: 1,249
Laminate over ceramic?
We're buying a condo as second home (our offer was accepted today!) and have a list of upgrades/improvements we plan to make before occupying. The condo has ceramic throughout the first floor (den/dining/kitchen/utility/bath). My wife wants to cover the ceramic in the den/dining area with laminate (about 300 sq ft). Assuming the tile is in good shape and uniformly level (which it is), is there any problem in doing this? I refuse to tear the tile up (personally, I like it) so this is a compromise
PPBART is offline   Reply With Quote
Old 03-03-2018, 06:00 PM   #2
Rewards Points: 17,912
Re: Laminate over ceramic?
I see a whole lot of issues with her idea.
#1, Laminate lowers the value of the whole unit.
#2, All the grout lines would need to be filled with embossing filler to level it out.
#3, There's going to be a big height difference between the floors if your not willing to remove the tile floor forming a trip hazard.
Old 03-03-2018, 07:14 PM   #3
Remodel and New Build GC
MTN REMODEL LLC's Avatar
Rewards Points: 2,224
Sorta agree with Joe... especially in regard to you'll likely encounter some custom "transition" work with the raised floor....maybe not a big issue and a couple of sloped transitions.
If reasonably flat (in plane) and you are using a good laminate click-lock (maybe 1/2" and at least 3/8 +) I think you can float it with a good padding/membrane.
I'm not sure at all that a laminate devalues a home versus tile at all... maybe just the opposite, depending on your local and home and market, and ultimately the tastes of a future buyer.
Congrats on the retreat/vacation ? home .
Good luck
MTN REMODEL LLC is offline   Reply With Quote
Old 03-05-2018, 10:25 AM   #4
PPBART's Avatar
OK, thanks for the replies. If I fill the grout lines to level the surface and later decide to remove the laminate, what would I have to do to remove the fill?
FWIW, I have several pieces of lam flooring (with padding attached) left over from previous projects, so I assembled and laid those in a room at our house that has similar tiles (12" square, 1/4" grout lines). In walking back and forth over that flooring, I honestly could not detect the grout lines.
Old 03-05-2018, 02:33 PM   #5
Rewards Points: 6,985
Personally I'm not convinced you need to fill the grout lines if you go with the thicker underlayment. Most grout lines are 3/16" or less and don't pose any serious issues in my mind.
Read the data sheet for the brand you are buying and perhaps email the mfg.
Colbyt
Retired drapery and home furnishings installer.
Colbyt is offline   Reply With Quote
I need to find a flexible transition between laminate and ceramic floors joyhasenbuhler Flooring 1 08-23-2014 11:30 AM
Ceramic Tile or Laminate Wood Flooring PearlWhiteGT Flooring 5 01-10-2012 01:56 PM
Ceramic or Laminate Flooring? helpless handyman Flooring 12 01-14-2009 06:44 PM
Counter top plastic laminate Gerry Kiernan Interior Decorating 4 10-13-2008 10:44 AM
