Laminate Over Ceramic - Flooring - DIY Chatroom Home Improvement Forum
Old 01-08-2016, 06:08 AM   #1
Rewards Points: 285
laminate over Ceramic
In my kitchen i have Ceramic Tile, can i put in Laminate Floor (floating floor) over the ceramic. Just didn't want the hassle of tearing out ceramic.Thanks?
lemley98 is offline   Reply With Quote
Old 01-08-2016, 06:50 AM   #2
Retired Moderator
Rewards Points: 7,174
Yep--you sure can---before you get your heart set on that, checkand make sure you have room to remove the dish washer.
A trapped dishwasher is a real serious problem----
Old 01-08-2016, 06:51 AM   #3
Retired Moderator
Also check the clearance at any exit door----
Old 01-08-2016, 07:03 AM   #4
Rewards Points: 285
Ok thanks.
Old 01-08-2016, 08:02 AM   #5
Rewards Points: 285
Do I need to put down a vapor barrier? There is a basement under neath.
Old 01-08-2016, 08:59 AM   #6
Rewards Points: 76
Just make sure you really want laminate in your kitchen. I know a lot of people go with it because it's easy to do but laminate and water do not mix. I would go with a vinyl plank type laminate in a kitchen before true laminate.
ponch37300 is offline   Reply With Quote
The Following 2 Users Say Thank You to ponch37300 For This Useful Post:
Gymschu (01-08-2016), oh'mike (01-08-2016)
Old 01-08-2016, 01:18 PM   #7
Retired Moderator
If you add laminate--you need the foam or rubber pad--but a separate vapor barrier is not needed.
Old 01-08-2016, 03:46 PM   #8
Pro Flooring Installer
rusty baker's Avatar
Rewards Points: 908
Be prepared for the noise. Laminate over ceramic can be noisy.
The ads in my post are there without my permission. I do not endorse any of the products.
Semi-Retired Installer
Installing since 1973
The Following User Says Thank You to rusty baker For This Useful Post:
oh'mike (01-09-2016)
I need to find a flexible transition between laminate and ceramic floors joyhasenbuhler Flooring 1 08-23-2014 11:30 AM
Ceramic Tile or Laminate Wood Flooring PearlWhiteGT Flooring 5 01-10-2012 01:56 PM
Ceramic or Laminate Flooring? helpless handyman Flooring 12 01-14-2009 06:44 PM
Counter top plastic laminate Gerry Kiernan Interior Decorating 4 10-13-2008 10:44 AM
