Laminate Flooring Gap At End Of Install - Flooring - DIY Chatroom Home Improvement Forum
Old 12-28-2018, 11:00 AM   #1
Rewards Points: 44
laminate flooring gap at end of install
I intended to install floating laminate plank flooring on the first level of my house as one piece. I started in the kitchen, went around the right into the dining room, down into the living room, and over to the left into the entrance way. When I met back with where I started, everything lined up properly except there's a 1/8 gap between the boards length wise. Did I do something wrong or is this typically what happens when you install a solid piece of flooring in multiple rooms? The only thing I can think to do here is slap down some t molding and call it a day, even though I really didn't want any transition pieces here.
Picture of the floor plan is below.
Side question, my T molding doesn't reach the floor. Do people usually just use extra adhesive in this case to fill the gap?
Doelman is offline   Reply With Quote
Old 12-28-2018, 06:53 PM   #2
Naildriver
chandler48's Avatar
Rewards Points: 1,830
Re: laminate flooring gap at end of install
You'll never be able to tie laminate to itself on a return course as you have described. Check the manufacturers data sheet. It may stipulate that you can only run so many feet without a transition. I would transition in doorways at any rate just so I could keep the runs in the next room square, since no wall has ever been built square. It allows also for the movement of the flooring, and you will have it with laminate. Transitioning at your two openings would have alleviated the problem.
Larry......
Half of Communications is Listening, and You can't Listen with your Mouth.
chandler48 is offline   Reply With Quote
Old 12-28-2018, 09:27 PM   #3
retired framer
Rewards Points: 8,558
Even if you are lucky enough to have things line up for the install different rooms will or can be exposed to different heat and moisture and you end up with gaps after the living in the house starts.
Old 12-31-2018, 11:57 AM   #4
Rewards Points: 44
Everything is finished and the flooring is squared up well everywhere, I snapped some lines before starting and it looked good. If I have a problems with the boards in different rooms expanding/contracting differently and I get anything poping up, I'll cut in transitions, easy enough.
This gap is seriously small, so no one has any ideas how to finish this without t molding?
laminate flooring gap at end of install-img_0011-1-.jpg   laminate flooring gap at end of install-img_0012-1-.jpg
Old 12-31-2018, 03:46 PM   #5
Naildriver
chandler48's Avatar
If it is click lock, you'll never be able to click the joint together since all the floor on both sides of the joint are flat. You appear to either be in a cased opening or doorway. Could you not go ahead and cut it and install a slip joint transition? You'll have to do it eventually.
Larry......
Laminate flooring install after linoleum torn out fenster4 Flooring 5 11-20-2016 08:10 PM
Laminate Flooring Installation - Guesstimate This Job For Me Please flowerchick Flooring 8 11-19-2011 12:57 PM
Strange engineered wood flooring install in Philippines (pics) Flt_Simulation Flooring 7 10-05-2009 09:00 AM
Basement Flooring: Laminate material atm Flooring 1 06-30-2009 10:34 AM
Peninsula install on Laminate flooring? mcaanda Building & Construction 1 05-22-2008 12:01 AM
