Laminate Flooring - Flooring - DIY Chatroom Home Improvement Forum
Old 10-02-2018, 09:05 PM   #1
Rewards Points: 40
Laminate flooring
Have a 20 by 20 room with click floating laminate flooring. There is water damage about 4 boards in from the side where the flooring was started from. It is cut around cabinets so really don't want to take up all the flooring to get to that side. Can you remove and reuse laminate from the starting edge?
dave438 is offline   Reply With Quote
Old 10-03-2018, 05:14 AM   #2
Naildriver
chandler48's Avatar
Rewards Points: 1,904
Re: Laminate flooring
The likelihood of your removing and replacing laminate flooring is almost nil. It is not a very good product to begin with, and any unclicking of the edges will almost surely damage them to where they can't be reused. Finding replacement pieces may be a challenge as well.
Generally there is no shortcut to replacing a click lock floor. You will need to start from one edge, remove all flooring to include the bad, then replace it all with either new, or salvaged pieces.
Larry......
Half of Communications is Listening, and You can't Listen with your Mouth.
chandler48 is offline   Reply With Quote
Old 10-06-2018, 07:03 PM   #3
Rewards Points: 18
I agree. Patching is basically impossible and won't look good. Your best bet is to just replace the flooring. A 20 x 20 room shouldn't be too hard to do, depending on the type of flooring you pick.
adam macross is offline   Reply With Quote
Old 10-11-2018, 06:53 AM   #4
Rewards Points: 6
I guess you should at first remove water leakage if any that can further damage your floor in future.
adamsmith182 is offline   Reply With Quote
Laminate flooring in frame house goodag2 Flooring 3 12-09-2012 07:00 AM
laminate flooring over laminate flooring bowbender6 Flooring 6 07-04-2012 09:27 PM
Laminate Wood flooring for duplex jukeboxpunk Flooring 16 06-23-2012 04:39 AM
Is there a durable laminate flooring for kitchens? samalex Flooring 5 11-03-2010 02:55 PM
Basement Flooring: Laminate material atm Flooring 1 06-30-2009 10:34 AM
