Laminate Flooring - Flooring - DIY Chatroom Home Improvement Forum
Old 10-05-2015, 06:58 PM   #1
Rewards Points: 18
laminate flooring
approximate cost to install laminated flooring
Tom Vlahos is offline   Reply With Quote
Old 10-05-2015, 08:00 PM   #2
Rewards Points: 18,384
One million dollars.
Think about it, no one here can see the house layout from here or the number of square ft..
No one even knows where your are so there's no way to know the local labor rate.
Get three local prices and then you'll know what the going rate is.
Why not install it yourself and save the money, it's not that hard a job.
Tom Vlahos (10-05-2015)
Old 10-05-2015, 08:03 PM   #3
Retired Moderator
Rewards Points: 7,174
Call your local home depot--they install---cost depends on the number of doorways--and number of corners and how flat the floor is.
Old 10-05-2015, 08:46 PM   #4
Rewards Points: 18
laminate flooring
Thanks Joe. My most sincere apologies. I am new to the forum & am still learning. Anyway I am in Southern California. Th job is 850 sq. feet of laminate.
I plan on installing it myself but just trying to get an idea of what it would cost to hire it out.
Old 10-05-2015, 08:56 PM   #5
Rewards Points: 125
The variables are too much to estimate without being on site. How complex is the space. What is the existing sub floor condition and material. . Any demo need to be done? You can buy a cheap car for 15 grand or a Ferrari for 500 G. Either one is a car. Best way is to call a couple of flooring contractors and get quotes. Of course I could go in to the fairness doctrine if you don't tend to hire one of them but I will stay off that soap box. Home Depot might be able to give a ball park.
jimn01 is offline   Reply With Quote
Old 10-05-2015, 10:26 PM   #6
Rewards Points: 18
Thanks Jim. Rectangular room with no closets or other projections. Concrete slab in good condition 375 sq.ft only demo involves removal of wall to wall carpet & pad.
Old 10-06-2015, 07:09 AM   #7
Retired Moderator
Tom, I just installed 420 feet this week---I charged about $1000 plus a hundred or so for odds and ends---customer supplied material (after I approved the choice)
This was just a small part of a larger project--so pricing reflects a lower cost than usual.
Base and shoe molding install was not included in that cost---was part of the trim project
Tom Vlahos (10-06-2015)
Old 10-06-2015, 10:08 AM   #8
Rewards Points: 18
laminate flooring
Thanks Oh Mike Have a nice day
Old 10-06-2015, 10:47 AM   #9
Rewards Points: 5,014
Actually I thought it was against the rules but.........
Adjust for material and labor cost of your area, 8.96 S.F
12' x 16'
Laminate flooring, strips,foam,adhesive, trim 192 S.F. 778.75
molding 15 L.F. 74.70
Adhesive 192 S.F. 18.00
material total 871.45
Material + Labor 1,719
ron45 is online now   Reply With Quote
The Following User Says Thank You to ron45 For This Useful Post:
Tom Vlahos (10-07-2015)
Old 10-06-2015, 05:59 PM   #10
Retired Moderator
While pricing questions are generally frowned upon, because they vary so much by location and job site---thus making them rather useless---
giving someone a general idea sometimes help to let a member decide on pursuing further info from a local contractor or giving up on an idea---
Old 10-07-2015, 05:32 PM   #11
Rewards Points: 18
laminate flooring
thanks Ron
The Following User Says Thank You to Tom Vlahos For This Useful Post:
ron45 (10-07-2015)
Laminate flooring in frame house goodag2 Flooring 3 12-09-2012 08:00 AM
laminate flooring over laminate flooring bowbender6 Flooring 6 07-04-2012 10:27 PM
Laminate Wood flooring for duplex jukeboxpunk Flooring 16 06-23-2012 05:39 AM
Is there a durable laminate flooring for kitchens? samalex Flooring 5 11-03-2010 03:55 PM
Basement Flooring: Laminate material atm Flooring 1 06-30-2009 11:34 AM
