Laminate Cut On Wrong Side Of Door Opening - Flooring - DIY Chatroom Home Improvement Forum
Old 10-02-2014, 10:07 AM   #1
Rewards Points: 2,262
Laminate cut on wrong side of door opening
What can I do to make it look decent.
Someone else installed the laminate. They cut it even with the wall instead of going in the 41/2" to have it under the door, then they stuck in a 4.5" strip and it looks bad. This is in a hall the ohter side in Lino in the bathroom.
There is no extra laminate and can not get a match.
Thanks for any help.
mae-ling is offline   Reply With Quote
Old 10-02-2014, 10:33 AM   #2
Rewards Points: 144
There are several ways to handle this and make it look good but pictures would help.
mako1 is offline   Reply With Quote
Old 10-02-2014, 01:06 PM   #3
Rewards Points: 17,912
Wide wooden threshold is one way.
Another way is to remove the 1/4 rd., remove the last row installed and slide the whole floor over. Add the missing piece and slid it back in place.
Old 10-02-2014, 08:03 PM   #4
Tileguy
Bud Cline's Avatar
Rewards Points: 558
It would be better if the laminate stopped under the center of the door of course, this is the way it is usually done. A typical interior door's center would be 11/16 from the drywall's surface on the door's side of the wall. However any transition-width should also be considered in the math. Your only option is to install a transition or reducer molding, the required piece would be about 3-3/4" in width. You may have to have one made. Any cabinet shop or carpenter can do so.
XXX
Old 10-03-2014, 07:26 AM   #5
And it would need a dado so the flooring could still expand and contract by not touching the flooring.
Old 10-05-2014, 10:55 PM   #6
Thanks guys, custom transition strip with dado on back it is.
Old 10-17-2014, 04:41 PM   #7
The piece of oak to make the custom transition will need to be 4" wide, how thin can I go? 3/8 would loo OK but 1/4" would look better. 1/2" or more is going to look bulky even with sloped edges.
Old 10-17-2014, 06:36 PM   #8
Rewards Points: 1,042
You can do 1/4"
Canarywood1 is offline   Reply With Quote
How To Build A Laminate Countertop BigJim How To Guides 44 07-08-2015 12:28 AM
Help!-need advise shed side roof construction-many pics RUMBLON Building & Construction 5 09-27-2012 09:15 AM
How do you install laminate flooring under door casings? Player Flooring 34 07-16-2010 04:55 PM
Timing for rebuilding of side entry: Help! navi_jen Remodeling 0 06-16-2010 10:02 AM
vapor barrier on the wrong side? mleriger General DIY Discussions 8 03-12-2010 06:46 AM
