Laminate To Carpet Transition Question - Flooring - DIY Chatroom Home Improvement Forum
Old 09-25-2014, 11:52 AM   #1
Rewards Points: 168
Laminate to carpet transition question
i have done many rooms in laminate before, so doing the job is no problem for me, im just not sure how to make this transition look good.....
i plan on doing my upstairs living room with laminate flooring, there is a staircase leading up to the room that is carpet, i want to keep the carpet on the staircase,
what is the best way to make the transition at the top of the stairs from the carpet to laminate look good?
i have attached a pic
Mikey1 is offline   Reply With Quote
Old 09-25-2014, 11:59 AM   #2
Rewards Points: 144
I would put a bullnose edge of wood to match your flooring where it meets the stairs.Above your last riser.Would look fine and no tripping hazards.
mako1 is offline   Reply With Quote
Old 09-26-2014, 12:33 PM   #3
Rewards Points: 168
thanks for the reply, im not too familliar with the bullnose term,
would you have a link to a picture handy?
Old 09-26-2014, 12:54 PM   #4
Rewards Points: 144
https://www.google.com/search?q=bull...2&ved=0CEwQ7Ak
Old 12-03-2014, 08:41 PM   #5
Rewards Points: 72
Why not rip off that carpet & refinish the stairs? IMO, it would look a lot better off with the carpet.
emmyshaw is offline   Reply With Quote
Old 12-03-2014, 09:10 PM   #6
Pro Flooring Installer
rusty baker's Avatar
Rewards Points: 1,668
Most stairs are built with plywood and for some people, slick wood staircases are not practical.
The ads in my post are there without my permission. I do not endorse any of the products.
Semi-Retired Installer
Installing since 1973
Old 12-05-2014, 07:14 AM   #7
Rewards Points: 168
yes my flooring is plywood underneath, and im not sure of how to finish stairs in laminate, so thats why i was going to keep the carpet, im a pretty handy guy, but i really think laminate on stairs would be out of my skill range
Old 12-05-2014, 07:42 AM   #8
Laminate should not be used on stairs anyway. It needs to float.
Old 12-05-2014, 07:44 AM   #9
Rewards Points: 168
thanks, thats what i was thinking, but wasn't sure
Old 12-07-2014, 08:29 PM   #10
Rewards Points: 72
Oh I see. I thought OP has hardwood underneath the carpet.
Old 01-19-2015, 05:37 AM   #11
Rewards Points: 104
Carpet color is not upto the mark. u should use some decent one
marks.fletchers is offline   Reply With Quote
Old 01-19-2015, 07:48 AM   #12
Do you think insulting the OP is helpful? Besides, different people have different tastes. I personally, find nothing wrong with the carpet color.
The Following 2 Users Say Thank You to rusty baker For This Useful Post:
Canarywood1 (01-19-2015), Dave Sal (01-21-2015)
Grinding concrete to remove carpet glue, and matching height of existing laminate... dmh0284 Flooring 12 04-22-2015 04:51 PM
Tile to carpet transition BlueBSH Flooring 5 03-21-2013 12:26 PM
Laminate or carpet pinkcamaro17 Flooring 2 07-09-2011 11:15 AM
Is it ok to carpet over laminate flooring? pekie Flooring 7 02-20-2010 01:20 PM
Hardwood and Laminate Transition seanf12 Flooring 2 01-14-2010 01:34 PM
