Laminate In Bathroom OK Or Bad Idea? - Flooring - DIY Chatroom Home Improvement Forum
Old 01-24-2016, 11:23 AM   #1
Rewards Points: 350
Laminate in bathroom OK or bad idea?
I will be remodeling my bathroom soon and I want to know if using laminate flooring would be OK or am I asking for trouble. I want to save on the time and expense of tile. Thanks
drew53813 is offline   Reply With Quote
Old 01-24-2016, 01:56 PM   #2
WhatRnsdownhill's Avatar
Rewards Points: 2,220
you can use laminate, but you will need to install a marble slab under the toilet as a moisture proof floor must go under the toilet, I dont believe laminate flooring meets that requirement...you will have problems with it separating when people get out of the tub or shower with wet feet, over time the top laminate will separate...real wood would be better, but you still need the marble slab..
WhatRnsdownhill is offline   Reply With Quote
Old 01-24-2016, 02:16 PM   #3
Rewards Points: 18,376
Just a really bad idea.
Any moisture and it's going to delaminate.
Old 01-24-2016, 04:10 PM   #4
A "Handy Husband"
rjniles's Avatar
Rewards Points: 224
Laminate in a bath is a horrible idea. Look at loose lay LVT. (Luxury vinyl tile).
My electrical answers are based on 2014 NEC, you may have local amendments.
Old 01-24-2016, 05:47 PM   #5
Rewards Points: 3,522
Can you provide more information on how this is done. Possibly a cross section drawing. I don't have a clue about marble slabs.
SeniorSitizen is offline   Reply With Quote
Old 01-24-2016, 05:55 PM   #6
here is a link on how one type of marble slab sits under a toilet..http://search.aol.com/aol/imageDetai...1bc75c631d64e5
Old 01-25-2016, 12:01 AM   #7
Pro Flooring Installer
rusty baker's Avatar
Rewards Points: 398
You are not supposed to put laminate under a stool anyway, it needs to float.
The ads in my post are there without my permission. I do not endorse any of the products.
Semi-Retired Installer
Installing since 1973
Old 01-27-2016, 06:29 AM   #8
Rewards Points: 4
From what I researched when looking for my laminate, everyone says never use laminate in a bathroom. Per the instructions on my Armstrong laminate, they say you "can" use it in a bathroom as long as you wrap the moisture barrier up the wall 2", glue all the planks together and completely silicone the perimeter. Even though possible I don't believe anybody would recommend it
lines4life is offline   Reply With Quote
ordering premade laminate countertops - advise please aribert Kitchen & Bath Remodeling 5 08-22-2015 11:46 PM
Wondering if it makes economic sence to replace a bathroom exhaust fan ChrisJJ HVAC 0 06-14-2011 11:36 AM
DuPont Laminate in Bathroom and kitchen wedge22 Flooring 4 02-17-2009 02:33 PM
Laminate Countertop in Bathroom Least Expense? houston Kitchen & Bath Remodeling 2 02-01-2009 01:19 AM
Counter top plastic laminate Gerry Kiernan Interior Decorating 4 10-13-2008 11:44 AM
