Keep Moisture Down - Flooring - DIY Chatroom Home Improvement Forum
Old 07-06-2013, 10:23 AM   #1
Rewards Points: 1,026
Keep moisture down
We pulled up all the old carpet in the 1br apt we rent and are installing new carpet. The apt is ground floor but seems to get damp. The floor is tile under the carpet. Is there anytthing we can put down under the carpet to keep the moister down? Thanks
Mstrlucky74 is offline   Reply With Quote
Old 07-06-2013, 11:47 AM   #2
ccarlisle's Avatar
Don't think there is...
What you have here is a 'moisture management' issue; by that I mean that you can't always prevent moisture from coming in, but you can manage that moisture once it does come in.
Now you do that by perhaps having a dehumidifier going down there during the summer months - but not during the winter months. You can also make sure you don't put down a moisture-sensitive carpet like cotton or wool - use nylon.
Removing the moisture could mean digging up the foundations or something that drastic...
“The average American woman is about 25 pounds heavier than she was in 1960...Recognizing obesity as a disease will help change the way the medical community tackles this complex issue that affects approximately 1 in 3 Americans,”
ccarlisle is offline   Reply With Quote
Old 07-07-2013, 12:51 PM   #3
Depends on how bad it is coming through
You can buy a moisture barrier from Lowes if not go to the local carpet shop and get one.
I am from the uk and we can get 2 types of moisture barrier, a paint on and one which you lay in a big sheet so i'm pretty sure the u.s would have the same.
midnightfox is offline   Reply With Quote
Old 07-07-2013, 02:55 PM   #4
MarginallyQualified
TarheelTerp's Avatar
Rewards Points: 4,582
And determining HOW it is coming in is the first step.
Is it atmospheric RH? Then the dehumidifier will do it.
But if is coming up through the floor... then you're in for some work.
TarheelTerp is online now   Reply With Quote
Old 07-13-2013, 02:05 PM   #5
The moisture is likely coming from below, and up thru the tile. The tile is probably porous and the grout surely is. Get some Damp Concrete Primer from Smith & Co (web-search will find), and use that first and then a good 2-part epoxy paint. That will seal the tiles and grout, and stop the moisture from coming thru.
Pro Painter is offline   Reply With Quote
Old 07-13-2013, 03:41 PM   #6
Rewards Points: 4,384
The first step in solving the problem, as mentioned, is to determine the cause of the moisture, so monitor the surface temperature of the tile for a few days at a few time intervals to determine if it is reaching dew point temperature.
What Is Bathroom Ceiling Moisture Problems evalewis Kitchen & Bath Remodeling 0 07-25-2012 04:26 AM
Cleaning brush StevenH Painting 19 02-05-2011 11:13 PM
Basement Moisture, what's this? bergerdude Building & Construction 1 06-11-2010 01:27 PM
Moisture meters and radiant concrete slab snowydaysrock Flooring 7 01-21-2009 06:33 AM
Moisture mystery in midst of shower redo Hisgirl Remodeling 3 01-05-2009 09:29 AM
