Joining Dricore Between Rooms - Flooring - DIY Chatroom Home Improvement Forum
Old 04-15-2018, 12:08 PM   #1
Rewards Points: 62
Joining dricore between rooms
I am doing hallway first and trying to go into a room now. But there would be a 2 inch gap along the wall of the larger room.
What's the proper way to go between rooms? Just cut it off and not join the rooms?
See photo
wrender is offline   Reply With Quote
Old 04-15-2018, 10:08 PM   #2
retired framer
Rewards Points: 20,392
Re: Joining dricore between rooms
So you start with a 2" strip you cut off a piece and hopefully you get to use the rest of the piece on the opposite wall. This should have been in the layout plan.
Is there a Minimum Temperature Rooms can be kept at? bb49 HVAC 27 01-10-2018 09:35 PM
Lost power to two Rooms and Cannot Get it Back Zinge Electrical 9 08-08-2011 09:13 PM
Do I need to add HVAC ducts to my below grade basement rooms if my daylight basement rooms already have HVAC supplies and returns? cmgoss HVAC 1 06-29-2011 05:12 PM
Joining wood floors in connecting rooms redcruz Flooring 1 06-03-2010 12:54 PM
Joining carpet and ceramic tile rooms TedT Flooring 10 05-21-2008 08:25 PM
