Issue With Using Florcraft Pre-mix Patch + Leveler - Flooring - DIY Chatroom Home Improvement Forum
Old 12-01-2014, 04:49 PM   #1
Rewards Points: 14
issue with using florcraft pre-mix patch + leveler
I plan on using peal and stick tile with grout. I put down 1/4 plywood and used what Menards told me to use for patching the seams and nail heads which was Florcraft Pre-mix patch + leveler. I put this down then the second day I sanded the areas. My problem is that it appears to be leaving a sandy type residue that I am not able to completely remove so the tiles end up with the sand particles on it and doesn't stick. I went back to Menards and they told me to use Sentinel Formula 811 Multi-Surface Adhesive Primer. I tried this and even put two coats on but it still seems like there is sand particles and the tile picks that up. I used a shop vac on the floor but these particles seem to stay there. Anything else that would work to make this smooth again?
T7433 is offline   Reply With Quote
Old 12-01-2014, 08:24 PM   #2
Rewards Points: 14
My issue is that this product seems like it doesn't dry, and has a gritty/sandy finish which causes the tile not to stick. Is this suppose to happen or does it take forever to dry.
Old 12-01-2014, 09:03 PM   #3
Tileguy
JazMan's Avatar
Rewards Points: 750
Try a powdered product and leave the pre-mixed stuff on the shelves where they belong.
Jaz
MARBLE from ITALY & GREECE -PERLATO-PERLATINO-BOTTICINO-THASSOS-SIVEC-VOLAKAS-CALACATTA- NAXOS-Slabs-Tiles-Custom containers shipped to you - [email protected]
Flood/Drainage Issue On Garage Man Door altc81 Building & Construction 2 04-17-2011 08:19 AM
Water patch cscpianoman Building & Construction 4 03-30-2011 10:50 AM
EPDM Roof Patch antelope420 Roofing/Siding 1 05-11-2010 08:20 PM
Bad driveway patch and seal work fastfan Landscaping & Lawn Care 1 09-09-2009 08:14 PM
