Intermittent Creaking, Popping On 2nd Floor - Flooring - DIY Chatroom Home Improvement Forum
Old 06-02-2015, 12:59 PM   #1
Rewards Points: 373
intermittent creaking, popping on 2nd floor
We replaced our carpet and padding three months ago. Prior to the install I put in 3" deck screws in many areas where the nails came loose and the subfloor plywood was loose. I have one area in the hallway that creaks/pops every so often. At first I was thinking it was the new carpet making the sound as its more of a popping sound. the 2x10 joists are running lenghtwise with the hallway. when my wife walks down the hall there is no noise, me at 220 it makes noise if I walk full stride and quickly.
I took photos of the subfloor and prior to new padding and carpet and the spot it's coming from is about 3 inches away from the wall. but it's in between two joists that are screwed down, so there does not appear to be anything I can fix from the top.
I was thinking I could remove a 2x2 ft section of drywall from the ceiling below which is a garage and stop the creaking from below. I am guessing there is a gap between the subfloor and joist and gluing shims in place will stop it?
Open to anyother suggestions.
thanks!
titan7 is offline   Reply With Quote
Replacing a 'dirt' floor. Ginnybugs Flooring 5 04-02-2014 08:01 PM
Floor damage from a 2nd floor bathroom toilet leak Tamber Plumbing 3 05-03-2011 12:10 AM
How to Stop the Wooden Floor from Creaking? loomb8 General DIY Discussions 2 11-20-2008 10:37 AM
Old old linoleum, can it take paint? molamola Painting 23 11-11-2008 07:32 PM
Carpeted floor creaking - suggestions/experience? WolfStock Flooring 12 06-30-2007 05:19 PM
