Interesting Floor Joist Spacing - Flooring - DIY Chatroom Home Improvement Forum
Old 01-30-2014, 10:12 PM   #1
Question
floor joist spacing for tile
Hi, I'm starting a bathroom remodel. Single level house built in 1991. I've removed the old vinyl flooring and 1/2" particle board underlayment. I was going to install ceramic tile, but it looks like I've got 32" OC joist spacing. Joists are thick though. It looks like all sistered 2x6's. Subfloor is 1 and 1/8th inch thick plywood. Seems strong when I jump on it. Will this work for tile? I know 16 OC is preferred, but will the relatively thick plywood subfloor and thick joists make up for the 32 OC spacing?
joregon3597 is offline   Reply With Quote
Old 02-01-2014, 06:23 AM   #2
Rewards Points: 996
i don't think it will. i would add joists. lets see a pic.
Fix'n it is offline   Reply With Quote
Old 02-01-2014, 10:33 AM   #3
Tileguy
JazMan's Avatar
Rewards Points: 750
Answer removed because an ad I did not authorize was inserted within my post.
Jaz
MARBLE from ITALY & GREECE -PERLATO-PERLATINO-BOTTICINO-THASSOS-SIVEC-VOLAKAS-CALACATTA- NAXOS-Slabs-Tiles-Custom containers shipped to you - [email protected]
Accepted tolerance for stud spacing? Proton Carpentry 14 01-24-2014 12:42 PM
Back Door tile spacing? Fireplace tile spacing? greentrees Tiling, ceramics, marble 2 08-24-2013 08:14 PM
wainscot stile spacing calculator dengle Carpentry 0 03-08-2012 03:56 PM
Grout Color Choice / Spacing jamiedolan Tiling, ceramics, marble 11 12-25-2008 02:00 AM
