Installing Vinyl Plank On Concrete Need Some Advice - Flooring - DIY Chatroom Home Improvement Forum
Like Tree1Likes
  • 1 Post By Nealtw
Old 09-24-2018, 11:48 AM   #1
Rewards Points: 8
Installing vinyl plank on concrete need some advice
Iím wanting to instal vinyl plank on my slab. Unfortunately the slab is not level. The guy at Home Depot said that I donít need to do anything to it before installing the floor. I donít believe him. Should I do self leveling compound or is there any alternatives to keep this project quick and inexpensive?
GrizzlyThunder is offline   Reply With Quote
Old 09-24-2018, 12:07 PM   #2
retired framer
Rewards Points: 9,242
Re: Installing vinyl plank on concrete need some advice
I believe the limits or right in the instruction, I think it reads some portion of an inch over so many feet.
MTN REMODEL LLC likes this.
Old 09-24-2018, 04:50 PM   #3
Retired Handyman/Painter
Johnny_inFL's Avatar
Rewards Points: 1,296
I would like to emphasize the importance of getting the floor level.
or - at least get any obvious "divots" filled.
my daughter has a house that has the vinyl plank on slab and there
are several areas in the house that were not leveled and now, 2 years later,
the adhesive has lost its tack and there is a loud proverbial POP when you
step on it. your weight presses it down and it grabs the adhesive for about
two seconds, then it POPS back up . . . very annoying.
I have no idea as how to fix it and do NOT want to venture into that skill set.
so ~ from personal experience - GET THE FLOOR LEVEL prior to applying the vinyl.
Johnny_inFL is offline   Reply With Quote
Old 09-24-2018, 05:04 PM   #4
Naildriver
chandler48's Avatar
Rewards Points: 1,948
Agree with the others. If not "Level", at least "Flat".
Larry......
Half of Communications is Listening, and You can't Listen with your Mouth.
chandler48 is offline   Reply With Quote
Old 09-24-2018, 05:14 PM   #5
Rewards Points: 8
I understand that leveling is very important. Iím trying to figure out whatís the best way or efficient way. Who ever did the slab was not concerned with a level surface. Itís got some highs and lows all over the place. Is self leveling compound my only option or are there others such as creating a sub floor?
Old 09-24-2018, 06:11 PM   #6
Naildriver
chandler48's Avatar
Using the vinyl planks your best bet would be SLC. Building a subfloor will put wood in contact with the moisture laden concrete. Life expectancy would be short and mold could grow.
Larry......
Old 10-11-2018, 07:27 AM   #7
Rewards Points: 6
Well said..
adamsmith182 is offline   Reply With Quote
Old 10-11-2018, 09:06 PM   #8
Home Repairer
Rewards Points: 468
Give us specifics on what floor you are considering. There are substantially thick vinyl click locks with a pvc core that are more forgiving than a single layer flexible vinyl floor. Floating would be my first suggestion instead of glue down.
czizzi is offline   Reply With Quote
(?) Need advice cutting 8" poured concrete in indoor basement / crawlspace RickDel Concrete, Stone & Masonry 14 09-13-2015 09:27 AM
Suggestions on where to Buy Vinyl Plank? Solaritu Flooring 8 05-02-2015 08:41 PM
Advice on Installing Interlocking Vinyl Tile beechers Flooring 7 01-28-2013 12:02 PM
Laminate or vinyl on a concrete basement floor? pjpjpjpj Flooring 36 09-03-2012 01:37 PM
Concrete (Cinder) Block Barebones Home : Seeking Advice granadaCoder Building & Construction 11 08-11-2012 07:03 AM
