Installing Tile 2nd Floor-Pros/Cons - Flooring - DIY Chatroom Home Improvement Forum
Old 03-10-2016, 11:22 PM   #1
Rewards Points: 2
Cool
I am researching wood look tile and engineered wood for my second floor. I really prefer the tile, but the weight concerns me. The subfloor is below standards but I am keeping it and either adding durock on top for tile or OSB on top for the engineered wood. I am concerned about sound so if I go with the engineered wood I will be nailing it down.
One post I read a guy said that the extra weight should not be a problem and could actually add increased stability to the home.
This is a 2,000 + townhome, end unit, Irving, Tx. So, about 1,000 SQ FT upstairs would be subfloor/mortar/durock/mortar/tile/grout. Was not sure if I still need a moisture barrier since this was not going to be wet areas.
I appreciate any thoughts or suggestions!
karen4cats is offline   Reply With Quote
Old 03-11-2016, 07:03 AM   #2
Rewards Points: 18,382
Start by telling us you mean by "subfloor is below standards".
Need to know the type of subfloor, how thick, what size and style of the joist and what's the free spans
That style of tile needs a dead flat non flexible surface.
Tile boards adds almost no added strength to the floor.
Installing Stone Veneer Over Tile (see pic) bpdavis0 Tiling, ceramics, marble 10 05-29-2012 09:06 AM
Installing bathtub on top of tile tvanharp Kitchen & Bath Remodeling 7 03-14-2011 08:43 AM
Installing floor tile but don't want grout gap to turn black overtime gatorade Flooring 4 02-07-2011 12:13 AM
Basement Floor Variance Allowance When Installing Ceramic Tile june New Member Introductions 0 10-26-2010 11:09 AM
Would installing ceramic tile in a crawlspace work well? Red Squirrel Tiling, ceramics, marble 11 07-22-2009 04:06 PM
