Installing Laminate Where Tile Was... - Flooring - DIY Chatroom Home Improvement Forum
Old 12-10-2011, 11:14 AM   #1
installing laminate where tile was...
Hi there! - First timer here. I just bought a new house and money is (of course) tight. I am paying to have someone install laminate flooring ( i have 6 dogs so wood is NOT and option) in my bedroom and master bath. in order to save money I told them that I would remove the carpet and tile flooring. I have the ceramic tile up and out however, between the concrete floor and what was the tile is what looks like either cement or mortor that the house builder used to set the tile floor in the first place.
Now the question...do I need to remove this before the laminate is installed? and if so how the heck do I do this?
Thanks so much for any advise
mmyers is offline   Reply With Quote
Old 12-10-2011, 11:19 AM   #2
Yes it needs to come up. You can do it with a concrete chisel and hammer, or rent or buy a compressor and air chisel. Not exactly my idea of fun.
Stanchek is offline   Reply With Quote
Old 12-10-2011, 11:39 AM   #3
Tileguy
Bud Cline's Avatar
Rewards Points: 558
Yes you do. That will teach you not to volunteer (in the future) for things you know nothing about.
The floor must be flat for the laminate installation (read the laminate instructions) and that probably means you will also have to grind your floors with a floor grinder. Chisels and hammer don't usually get the floor smooth.
Old 12-10-2011, 11:50 AM   #4
Pro Flooring Installer
rusty baker's Avatar
Rewards Points: 400
And if the dogs urinate on the laminate, the joints will swell. The only really dog-proof flooring is concrete.
The ads in my post are there without my permission. I do not endorse any of the products.
Semi-Retired Installer
Installing since 1973
Old 12-10-2011, 07:49 PM   #5
Rewards Points: 272
Why would you want to install laminate in a washroom, NOT a good idea ....in my opinion.
fixrite is offline   Reply With Quote
Old 12-10-2011, 07:53 PM   #6
Rewards Points: 18,384
Why did you remove the tile in the first place.
Tile would be a much better option then laminite.
Installing bathtub on top of tile tvanharp Kitchen & Bath Remodeling 7 03-14-2011 08:43 AM
Installing Porcelain tile, complete guide? Total Sugar Flooring 5 03-07-2011 10:22 PM
installing shelving on tile backsplash indignatz Remodeling 7 11-05-2010 07:06 AM
laminate floor, basements and asbestos tile geandham General DIY Discussions 1 09-23-2009 08:45 AM
Replacing tile with laminate - Bad idea? Regina Phalange Flooring 6 11-22-2008 07:12 PM
