Installing Hardwood Flooring With Hand Tools? - Flooring - DIY Chatroom Home Improvement Forum
Old 03-06-2015, 09:38 AM   #1
Rewards Points: 218
installing hardwood flooring with hand tools?
we are going to be installing about 170sqft of hardwood flooring in a remote location.
I know, I know - The Right Tools For the Job. But I don't really want to buy a stapler/nailer for just one job and I don't want to drive hours to rent and return one.
is it reasonable -- the extra time required aside - to install an entire room of hw flooring with hand tools? hammer, nails and (OK, a power) drill for pre-drilling pilot holes for the nails?
pjstock is offline   Reply With Quote
Old 03-06-2015, 10:06 AM   #2
Rewards Points: 1,602
Do you have the flooring already? You can can get a floating floor or you can even glue down instead of nailing.
mikegp is offline   Reply With Quote
Old 03-06-2015, 10:29 AM   #3
Rewards Points: 218
I have the flooring. Got a deal (famous last words? maybe.) on 170sqft of remaindered 3/4" x about 3" oak @ 0.65c / sqft. ($110 total) an offer I couldn't refuse. Nice stuff.
so you can see why renting a nailer would more than double the cost of the install.
but if I have to, I will.
Old 03-06-2015, 10:49 AM   #4
Rewards Points: 144
There were wood floors long before there were flooring nailers.
mako1 is offline   Reply With Quote
Old 03-06-2015, 10:58 AM   #5
Rewards Points: 42
170 ft sq is not much to install for many.
The main thing is pre drilling the flooring and getting it tight to the previous board.
Do you have electricity where you'd be doing this?
A battery operated drill may help…and a nail set.
Larry K. is offline   Reply With Quote
Old 03-06-2015, 11:04 AM   #6
Rewards Points: 218
exactly, if I was doing 1500 sqft, it would be another matter, but it's just one room at this point.
and yes, there's power and I have a good cordless drill and a nail set (or as another post suggested, a cold chisel)
and as that other post also noted, a lot of flooring was installed before the advent of the pneumatic nail/staple gun.
I think I can do it. when I installed some cork flooring I used a scrap piece that I could whack with a hammer to set the good pieces snugly in place.
Old 03-06-2015, 11:08 AM   #7
Rewards Points: 144
No problem just watch the angle of the nail thru the tongue to make sure the next piece will fit tight.
Old 03-06-2015, 11:31 AM   #8
Rewards Points: 42
Another thought is to set the flooring inside (open the boxes and spread it out a little) to acclimate it to the indoors where it will be installed.
how to tie new hardwood floor into existing hardwood flooring b16bri Flooring 2 04-29-2013 06:13 PM
3/4 Hardwood Flooring over sufficient subfloor? bout time Flooring 3 06-20-2011 05:15 AM
New to installing Hardwood Flooring Quicksilver Flooring 6 05-17-2011 06:59 PM
Installing 3/4" Engineered Hardwood over Particle board New_Floors Flooring 4 01-26-2011 09:23 PM
Installing engineered flooring in the Philippines Flt_Simulation Flooring 15 07-21-2009 08:00 PM
