Installing Engineered Flooring 1st Timer - Flooring - DIY Chatroom Home Improvement Forum
Old 09-07-2015, 10:15 PM   #1
Rewards Points: 192
Installing engineered flooring 1st timer
Hello all, installing 200 sq ft of flooring in our 1st floor living room. This will be installed on plywood which currently is carpeted. I have 2 questions....
1st question:
The engineered flooring we purchased has a veneer on both sides, one side (top) obviously finished, but the middle is constructed of what looks to be mdf?!? Is this just a crappy engineered flooring? It was $3.00 a sqft Canadian at Home Depot and it's made in China. Should I be looking for something else or elsewhere for flooring? Here are 2 pics of it.
Installing engineered flooring 1st timer-imageuploadedbytapatalk1441678718.732330.jpgInstalling engineered flooring 1st timer-imageuploadedbytapatalk1441678861.704193.jpg
2nd question: how should I go about installing it in this room with these thresholds? Should I remove them or butt against the threshold? Or add a t moulding on top of the threshold (I think this would look busy)?
Installing engineered flooring 1st timer-imageuploadedbytapatalk1441678393.645912.jpgInstalling engineered flooring 1st timer-imageuploadedbytapatalk1441678409.467822.jpgInstalling engineered flooring 1st timer-imageuploadedbytapatalk1441678441.690628.jpgInstalling engineered flooring 1st timer-imageuploadedbytapatalk1441678478.827566.jpg
badhaircut is offline   Reply With Quote
Old 09-08-2015, 06:44 PM   #2
Rewards Points: 1,042
Any engineered flooring i've seen has always had a plywood substrate, hard to tell from the pic what you have, but shouldn't be too hard to tell if it's MDF.
If your flooring will butt up against the marble strip your good to go, if not probably need a transition unless you can get creative and "make" it match.
Canarywood1 is offline   Reply With Quote
Old 09-08-2015, 07:04 PM   #3
Rewards Points: 192
The top is definitely wood and so is the bottom but the middle is mdf so I'm wondering if I should buy something else? And it's made in China so I'm worried about its longevity
Old 09-08-2015, 09:31 PM   #4
If it's mdf i'd be leery too, a lot of the stuff from lumber liquidators is from China beware.
Old 09-08-2015, 09:45 PM   #5
Rewards Points: 996
assemble a pad of that flooring, say, 4'x4'. get a chair that has wheels on it = office or kitchen chair. put the chair on the pad, sit down, roll around.
do the wheels leave ANY marks ?
i did this to some engineered i bought from home depot, years ago. the wheels left ruts in the flooring deep enough to flow water. back that stuff went.
Fix'n it is offline   Reply With Quote
Installing hardwood flooring tomseeley Flooring 6 09-10-2015 10:36 AM
First Timer - Questions About Hardwood Flooring for Stairs sunshine54 Flooring 0 10-16-2011 11:44 PM
Baseboard Gap Options? Installing Floating Vinyl Flooring Today. Please Help. skeeter505 Flooring 1 09-17-2011 08:46 AM
Help installing wall switch light timer Aube TI071 Rachey Electrical 10 12-24-2010 12:02 PM
TrafficMaster Engineered Wood Flooring in Basement Vermonster Flooring 4 04-02-2008 12:23 PM
