Installing 12x25 LVT Tile From Original Subfloor - Flooring - DIY Chatroom Home Improvement Forum
Like Tree1Likes
  • 1 Post By JazMan
Old 10-16-2017, 02:35 PM   #1
Rewards Points: 14
Installing 12x25 LVT tile from original subfloor
I have Shaw 12" x 24" luxury vinyl tiles. 10' x 10' kitchen. First time with the luxury vinyl.
What is the best way to put down the 7/16 OSB, then 5mm TriPLY, self leveling compound, and then tile? Using Shaw 200 TPS glue with 1/16 trowel.
Should I level with the SLC on the osb before adding the underlayment? Or staple down the underlayment and then the SLC?
The floor has been stripped down to the original 3/4" thick 5.5" wide diagonal planks. There are noticeable hills and dips. The planks have been screwed to the joists with 2" SPAX construction screws.
My plan was to install the 7/16 OSB perpendicular to the joist and screw down to the sub floor with 1.5" SPAX construction screws. Screws placed every 8" across edge and 12" in field (but not into joists). 1/8" spaced between boards.
Underlayment will be added perpendicular to OSB and stapled (1.5" ?) with a 1/4" crown stapler every 3" edge and 6" in the field.
Thank you.
rjcrust2015 is offline   Reply With Quote
Old 10-16-2017, 06:11 PM   #2
Naildriver
chandler48's Avatar
Rewards Points: 4,328
Re: Installing 12x25 LVT tile from original subfloor
If you are installing new OSB and a new underlayment of flooring grade plywood (not luan), I don't really see the need for SLC unless you are trying to get rid of a slope. It should be fairly flat if you staple the underlayment to the OSB.
Larry......
Half of Communications is Listening, and You can't Listen with your Mouth.
chandler48 is offline   Reply With Quote
Old 10-16-2017, 07:07 PM   #3
Tileguy
JazMan's Avatar
Rewards Points: 750
Somebody tell me how installing more osb & underlayment ply is gonna remove "There are noticeable hills and dips."
The new layers will improve the dips while making the hills larger. He needs SLC if the subfloor can't be fixed before the OSB. Got a specific SLC you're planning to use?
Jaz
MARBLE from ITALY & GREECE -PERLATO-PERLATINO-BOTTICINO-THASSOS-SIVEC-VOLAKAS-CALACATTA- NAXOS-Slabs-Tiles-Custom containers shipped to you - [email protected]
Old 10-16-2017, 08:03 PM   #4
Rewards Points: 14
I have not looked at specific SLC yet. Any recommendations?
Old 10-17-2017, 05:20 AM   #5
Naildriver
chandler48's Avatar
Fix the hills and dips first. IMO SLC is a last resort. Fix the construction first or the SLC will only crack and become useless later on as the hills and dips expand and contract with the building.
Larry......
Old 10-20-2017, 08:06 AM   #6
Rewards Points: 14
I plan to work on the floor this weekend. I see how flat the sub floor is in relation to the hills and dips and will fix what I can on the surface.
I purchased "Henry 565" SLC (with the 564 primer) from my trusty local Lowe's. If there are any imperfections after I put down the top underlayment then I will use it to smooth out the floor.
I am not so worried about a true level floor as I am a flat floor. If I had to spend time leveling my house I would be here until retirement. Not sure what is worse, chasing down all the holes to caulk to leveling and plumbing this place.
Old 10-20-2017, 01:23 PM   #7
Tileguy
JazMan's Avatar
Rewards Points: 750
I'm not so thrilled about 7/16" OSB, but ok.......
NO. Underlayment goes perpendicular to the joists just like every other layer. Just offset the sheets both ways.
Better check that Triply meets the requirements for the SLC. Doesn't sound like it does since it's supposed to be Exposure 1 rated.
That 564 primer says it's for concrete.
Remember if you try to make the floor flat and you have a high spot, you will have to fill the entire area until it reaches the hilltop. Easier to lower the hill than to raise the valley.
Jaz
chandler48 likes this.
The Following User Says Thank You to JazMan For This Useful Post:
rjcrust2015 (11-13-2017)
Old 11-13-2017, 01:35 PM   #8
Rewards Points: 14
Follow up - Here is what I did. Once completed, there were minimal dips and bumps. "Overall" the floor is level, where it is not, the slope flows away from the sink and dishwasher. The hills and valleys ended up being in areas where there were cabinets or appliances and I felt the need to so the SLC was not worth the effort on this particular project.
- Screwed original subfloor to joists using 2 " Spax construction screws and hammered down any of the original nails. All squeaks were gone.
- Added 7/16 OSB using 1 1/4 Spax construction screws perpendicular to the joists (1/8" space between sheets and 1/4" from walls) every 6 - 8 "
- Added 1/4" ply using 1 1/2 narrow crown staples every 4 to 6" perpendicular to joists but not lined up with OSB in order to overlap seams
- Glued the luxury vinyl using Roberts 2310 adhesive and 1/16" trowel
- Spread the entire floor and began laying tile around 50 minutes from the start (helps to use 3/16 T spacers when doing the brick layout
- Used the Tek vinyl tile grout from Lowes
We selected vinyl now for he young ones running around. They are not supposed to be in the kitchen, but this was the choice over ceramic. Hoping it lasts till they are old enough to replace with ceramic. My only concern is the grout cracking. I have not lived in the home long so I don't know the full history of settling, humidity, etc. in this 1950's home. Worse case, I rip up and do it again. Helps when the kitchen is small
Thank you all for the help.
Kitchen project: subfloor for tile WillK Kitchen & Bath Remodeling 0 10-03-2016 10:47 AM
Opinions on my subfloor for ceramic tile Bret86844 Flooring 11 04-05-2016 10:06 AM
Tile installation with plank subfloor, only 3/4" to work with adamsb6 Flooring 5 05-22-2013 02:34 AM
Bathroom tile installation demolition Kitchen & Bath Remodeling 4 04-10-2011 07:48 PM
installing shelving on tile backsplash indignatz Remodeling 7 11-05-2010 06:06 AM
