Install Quarter Round When There Is Large Gap Underneath The Baseboard? - Flooring - DIY Chatroom Home Improvement Forum
Old 05-17-2013, 07:55 PM   #1
Rewards Points: 24
Install Quarter Round when there is large gap underneath the baseboard?
Hello.
I recently purchased a house and ripped out all the carpets (so I can refinish the hardwood floor underneath).
I noticed is that the gaps underneath the Baseboard for two walls are fairly big. The biggest spots are 1/2 inch to 11/16th of an inch. While the quarter mould would cover it, nailing the mould to the baseboard will be impossible in those areas.
Just wondering what are my options. Should I remove and reattach the baseboards? (Will require redoing all the baseboards in both rooms) nail the quarter into the floor? use glue?
Thanks.
[pictures of the gap underneath the baseboard]: http://imgur.com/a/p68lf
Dimeron is offline   Reply With Quote
Old 05-17-2013, 08:01 PM   #2
Framing Contractor
Rewards Points: 56
Use a taller molding.
sixeightten is offline   Reply With Quote
The Following User Says Thank You to sixeightten For This Useful Post:
Dimeron (05-20-2013)
Old 05-17-2013, 08:12 PM   #3
Rewards Points: 17,912
I'd use 3/4 X 1/2 shoe moulding instead of 1/4 round.
Old 05-17-2013, 08:17 PM   #4
funfool's Avatar
Rewards Points: 534
And press the 1/4 round or shoe molding against the baseboard and nail it to the floor.
Just be aware, this issue is from a bigger problem and is the foundation sinking.
I would be all over the underside of that house and want to figure out why it is sinking in those areas.
funfool is offline   Reply With Quote
The Following User Says Thank You to funfool For This Useful Post:
Old 05-17-2013, 08:17 PM   #5
Rewards Points: 24
Hello.
I thought about it, but even with 3/4 inch tall shoe mould, It will barely cover the gap, and I will still not be able to nail the moulding to the baseboard.
Do people typically nail the shoe mould to the floor instead?
Thanks, the house inspector didn't mention anything, hopefully it is not a foundation issue, but I will double check (anything specific I should look for, one of the gap is on the second floor).
Although it should be noted those baseboard are really badly done. One of the baseboard for example is slightly higher than the other baseboard at the interior corner, and the other baseboard had been sawed short so a telephony line can be run beneath it.
Old 05-17-2013, 08:20 PM   #6
funfool's Avatar
Rewards Points: 534
I do not mean to scare you by saying it is foundation issues.
If this home is less then 1 year old we want to talk to the builder and his warranty.
If this home is 100 years old, it is doing very well.
More info is needed.
Old 05-17-2013, 08:27 PM   #7
Rewards Points: 24
Its right in between. it is 50 years old.
Old 05-17-2013, 08:38 PM   #8
I most often see this with ballon wall constructed homes.
Termites, powder post bettles, settling foundations, oh the joys of an old house.
Old 05-17-2013, 08:52 PM   #9
funfool's Avatar
Rewards Points: 534
I have seen it several times, sometimes is obvious that is wood damage and should be repaired right away.
Other times, is just old age and common settling going on. But I would want to know as soon as I know there is a issue.
Old 05-18-2013, 10:59 AM   #10
Rewards Points: 81
/a/p68lf
Just rip some backing material to fill the gap under the base where needed and secure that to the bottom plate then nail the quarter round into that.
one cut is offline   Reply With Quote
The Following User Says Thank You to one cut For This Useful Post:
Old 05-18-2013, 12:37 PM   #11
Rewards Points: 152
This is what I would do
stradt03 is offline   Reply With Quote
The Following User Says Thank You to stradt03 For This Useful Post:
Old 05-19-2013, 09:46 PM   #12
that was going to be my suggestion, I have done that a few times works like a charm
ubcguy89 is offline   Reply With Quote
The Following User Says Thank You to ubcguy89 For This Useful Post:
Old 05-20-2013, 06:46 PM   #13
Rewards Points: 24
Thanks everyone for the tips.
I will get those 3/4th of an inch shoe moulds and then nail it to the floor then. Will also see if I can find any thin wood strips that I can stuff into the gaps.
Thanks all.
Old 05-21-2013, 10:14 AM   #14
Rewards Points: 141
I'm a little late, but I can't believe a settling foundation is the cause of the gap. The walls are attached to the foundation. Everything would sink, wouldn't it?
You say you ripped out carpet. My guess is, the existing baseboard was installed (or maybe reinstalled) after the carpet was put in because the baseboard was originally down at the hardwood floor level when the house was built.
You say some of it looks like it was poorly done. If it were me, and I hate doing more work than necessary, I'd just redo all the baseboards. If you're going to go through the work of refinishing those hardwood floors, why top it off with sketchy looking baseboards?
Brad Nailer is offline   Reply With Quote
Old 05-22-2013, 09:51 PM   #15
Thanks all.
You should never nail shoe into the floor!!!! You MUST CUT BLOCKS FOR UNDER THE BASE
Trimming out quarter round replacement window OKDrew63 Carpentry 6 07-07-2012 09:57 AM
Miter saw kickback with oak quarter round KukuChoma Carpentry 19 01-11-2012 08:52 AM
Baseboard or Quarter Round for Laminate Floor sweaty General DIY Discussions 10 08-03-2011 04:15 PM
Laminate Flooring Quarter Round Cuts no3jack Flooring 1 12-11-2006 08:30 PM
Quarter round and baseboard justtired Flooring 1 09-30-2006 04:39 PM
