Identifying Laminate: How Screwed Am I? - Flooring - DIY Chatroom Home Improvement Forum
Old 03-11-2016, 04:18 PM   #1
Rewards Points: 40
Identifying laminate: how screwed am I?
Hi everyone,
Does anyone know how I can figure out the brand of this flooring? I've checked a few places with no luck.
Installation date: At least 3 years ago.
Dimensions are 5/16" x 7 11/16"W x 47 13/16"L
Installation type: Angle angle
It has a slightly raised grain texture on the face, and the back side is sort of a maroon color. Anyone recognize it? Sorry for the pic quality. Thanks!
pointguard is offline   Reply With Quote
Old 03-11-2016, 08:51 PM   #2
Rewards Points: 199
You omitted the obvious information. Why do you want to identify it? Fear of cancer causing emissions or hope to find more of the stuff? Lumber Liquidators was offering test kits for free if you are worried. If you hope to match it track down the former owners and ask.
Arlo is offline   Reply With Quote
The Following User Says Thank You to Arlo For This Useful Post:
pointguard (03-13-2016)
Old 03-11-2016, 09:25 PM   #3
Rewards Points: 40
Sorry about that, yeah I need to replace a couple pieces and asking the previous owners isn't an option unfortunately.
Old 03-11-2016, 10:48 PM   #4
JUSTA MEMBER
Rewards Points: 1,528
How is it attached to the floor, often they stamp on the underside a manufacturers stamp.
It might take pulling several pieces before you find a stamp, but it might not.
Previous owner should have left you a package with all the paperwork for this and any other appliances/ lighting/ faucets, etc. That they had installed.
ED
de-nagorg is offline   Reply With Quote
The Following User Says Thank You to de-nagorg For This Useful Post:
Old 03-12-2016, 09:20 AM   #5
Rewards Points: 996
Re: Identifying laminate: how screwed am I?
take up the pieces you need from a place that will have furniture or whatever over them.
and swap them with the damaged pieces.
at 3 years, you are right on the edge of never finding new stuff.
Fix'n it is offline   Reply With Quote
The Following User Says Thank You to Fix'n it For This Useful Post:
Old 03-12-2016, 10:56 AM   #6
Super Moderator
Gymschu's Avatar
Rewards Points: 308
Any local flooring stores nearby? Any big box stores close? You could take a piece to those places to see if anyone on staff recognizes it. It looks like a fairly common laminate. Someone that's been in the flooring biz for a long time could probably tell you the make after a quick glance. Worth a try if you don't have any luck with the other suggestions.
"In the heat of battle, my father wove a tapestry of obscenity........."
The Following User Says Thank You to Gymschu For This Useful Post:
Old 03-12-2016, 11:43 AM   #7
Rewards Points: 270
From the color of the underside, I'd guess that's Pergo. Iu put some down bout 5 years ago. The underside looked the same. Just a guess though.
b-boy is offline   Reply With Quote
The Following User Says Thank You to b-boy For This Useful Post:
ordering premade laminate countertops - advise please aribert Kitchen & Bath Remodeling 5 08-22-2015 11:46 PM
Ditra under Laminate Floor? HECO Flooring 3 04-30-2012 09:00 AM
laminate moving in one direction nlmedic Flooring 2 03-01-2011 08:38 PM
Counter top plastic laminate Gerry Kiernan Interior Decorating 4 10-13-2008 11:44 AM
Laminate layout, underlay for concrete subfloor? Jen25 Flooring 2 09-30-2008 01:04 AM
