I Thought I Had Flooring Cut Correctly Until I Started To Install Quarter Round. - Flooring - DIY Chatroom Home Improvement Forum
Like Tree12Likes
Old 10-05-2017, 08:28 PM   #1
Rewards Points: 18
I thought I had flooring cut correctly until I started to install quarter round.
What options do I have beside tearing up the flooring. I have 6 doorways in a small hallway, about 7 feet long.
Colonelclaypool is offline   Reply With Quote
Old 10-05-2017, 08:37 PM   #2
Rewards Points: 18
Re: I thought I had flooring cut correctly until I started to install quarter round.
Got the pictures showing now, as you can see I didn’t cut under the door jamb properly.
Old 10-05-2017, 08:38 PM   #3
Usually Confused
lenaitch's Avatar
Rewards Points: 94
That one plank looks pretty ragged. Any chance you can lift it and re-do? Otherwise, you could try and see if a plinth block and wider baseboard would cover it. That would require you to pretty much re-do all of the trim, but it looks like it might want updating anyway. Maybe the pros have some handy tricks.
lenaitch is offline   Reply With Quote
The Following User Says Thank You to lenaitch For This Useful Post:
Colonelclaypool (10-05-2017)
Old 10-05-2017, 08:44 PM   #4
RRH
Rewards Points: 1,354
Goggle
ROSETTE TRIM BLOCK
Use a multimaster to cut out some of the door trim. Should not but may have to add a wooden spacer to make the trim block thicker.
Should actually look like a improvement since the door casing looks rough anyway.
RRH is offline   Reply With Quote
Old 10-05-2017, 08:44 PM   #5
Rewards Points: 18
Honestly I donít know how I got those board in place to begin with. It was myself and two brothers, after all the boards were in place nothing would budge at all. Iím sure itís possible to pull the boards up but that ragged one we had a hell of a time with and cut it at least 3 times before we settled for that. New trim may be my best bet but Iíll wait for a few more replies, thanks!
Old 10-05-2017, 08:46 PM   #6
retired framer
Rewards Points: 464
As suggested plinth blocs, here are some to look at.
http://www.thejoyofmoldings.com/about-plinth-blocks/
The other molding could be removed and backed with another piece of wood to make it thicker but still look the same.
Old 10-05-2017, 08:47 PM   #7
retired framer
Rewards Points: 464
So you are the guy that cut it three times and it is still to short.
Sorry just had to say it.
Dave Sal, lenaitch, ZZZZZ and 2 others like this.
The Following User Says Thank You to Nealtw For This Useful Post:
Old 10-05-2017, 08:53 PM   #8
Usually Confused
lenaitch's Avatar
Rewards Points: 94
Was beer involved?
SPS-1 and ron45 like this.
Old 10-05-2017, 08:58 PM   #9
Rewards Points: 18
Unfortunately looks like it haha.
Old 10-05-2017, 08:59 PM   #10
Rewards Points: 18
Was beer involved?
Beer and a strict timeline donít mix well
Old 10-05-2017, 09:00 PM   #11
Rewards Points: 18
Perfect! Iíll grab some tomorrow and give that a shot.
Nealtw likes this.
Old 10-05-2017, 09:09 PM   #12
Usually Confused
lenaitch's Avatar
Rewards Points: 94
The cause, and solution, to all the world's problems.
Homer Simpson
Old 10-06-2017, 08:57 AM   #13
Rewards Points: 692
Another option is to remove the baseboard, undercut the drywall, cut a strip of flooring that is about 1/4" narrower than the edge of the board and wall, lay it in the groove and slide it toward the miscut board. Square off the miscut board to get a straight edge. Where the miscut goes around the door casing slide the strip under the door casing. You may have to do some work to disguise the new joint lines. I use this technique when I get to a wall and need only a narrow strip to avoid a gap between the baseboard and floor....I remove the baseboard, undercut the drywall, slide the strip under the drywall, finish installing the floor, pull the narrow strip toward the last floorboard, reinstall the baseboard.
The other recommendations will work but the baseboard and door casing profiles will be different from those in the rest of the house.
mark sr likes this.
JIMMIEM is offline   Reply With Quote
The Following User Says Thank You to JIMMIEM For This Useful Post:
Colonelclaypool (10-06-2017)
Old 10-06-2017, 11:36 AM   #14
Oso954's Avatar
Rewards Points: 130
You need to learn how to cut and install a quarter round return (or end cap).
Makes the install look a lot more professional as compared to leaving a plain straight cut end on it.
http://www.laminate-flooring-install...d-returns.html
47_47 likes this.
Oso954 is online now   Reply With Quote
The Following User Says Thank You to Oso954 For This Useful Post:
Old 10-06-2017, 06:51 PM   #15
Rewards Points: 18
I ended up tossing that quarter round and will just paint it and decided to do it right with the returns as well! Thanks for the input.
small quarter round moulding mf915 Flooring 11 09-30-2009 01:14 AM
Intersection between chair rail and quarter round stubits Carpentry 14 08-01-2009 09:05 AM
Installing Quarter Round shanmon Flooring 4 07-19-2007 01:59 PM
Quarter round on round outside corners biyoba Flooring 4 01-07-2007 08:39 PM
Laminate Flooring Quarter Round Cuts no3jack Flooring 1 12-11-2006 09:30 PM
