How Would You Seal Exterior Staircase Made Of Plywood? - Flooring - DIY Chatroom Home Improvement Forum
Old 11-20-2015, 08:47 PM   #1
Rewards Points: 42
How would you seal exterior staircase made of plywood?
Hello,
My 13 year old staircase is covered with exterior carpet. The steps and risers are plywood, I believe not pressure-treated.
Over the years, the bottom steps have been exposed to dripping water, and ground-level moisture, due to the occasional rain we get in San Diego county. They are rotted and I'm replacing the plywood.
I'm looking into ways to keep that rainwater away from the stairs, but I don't yet know whether I'll succeed.
The carpet probably is trapping moisture between itself and the wood, which would contribute to the problem. Are there non-ugly alternatives to carpet? The wood is not attractive enough to be left bare, in my opinion.
Actually, I'd rather not go through the trouble of replacing the carpet. Can I just use a really good sealant on top of the wood, so the carpet's moisture won't matter?
As an alternative to a deck sealant treatment, should I consider something like SikaFlex Self-Leveling Sealant? Or even ordinary caulk, spread over all the wood?
From experience, I suspect that ordinary house paint wouldn't seal well enough.
Thanks in advance for your ideas!
patchtaper is offline   Reply With Quote
Old 11-21-2015, 04:49 AM   #2
Pro Flooring Installer
rusty baker's Avatar
Rewards Points: 1,668
Paint would be better than the carpet. Carpet holds the moisture, a painted surface dries faster.
The ads in my post are there without my permission. I do not endorse any of the products.
Semi-Retired Installer
Installing since 1973
Old 11-21-2015, 09:48 AM   #3
Rewards Points: 17,914
Post a picture.
No form of plywood is going to work for outside stairs, not even marine plywood.
Old 11-21-2015, 11:19 AM   #4
Rewards Points: 1,042
I don't think a sealant is what your looking for, a better alternative would be a water repellent, google "Prosoco" to see if it's available in your area.
Canarywood1 is offline   Reply With Quote
Old 11-21-2015, 02:25 PM   #5
Rewards Points: 42
Here are photos
As you can see, the "side walls" supporting the steps are plywood too, and on the left side there is siding panel material concealing the plywood.
That metal trim along each side of the steps covers the ugly edges of wood. And the metal is sized with the thickness of the carpet accounted for. If I get rid of the carpet, I must do something about the edges previously covered by that metal.
I fear that paint, if I found any tough enough to be walked on, would be slippery. Maybe some slip-resisting treads could be placed on top of the paint.
Old 11-21-2015, 02:30 PM   #6
Super Moderator
Gymschu's Avatar
Rewards Points: 6,850
You can add Shark Grip to your paint to provide traction.
"In the heat of battle, my father wove a tapestry of obscenity........."
Old 11-23-2015, 11:37 AM   #7
Rewards Points: 4,434
Maybe....
http://www.completemobilehomesupply....Steps_s/50.htm
ron45 is offline   Reply With Quote
French doors - bottom seal replacement adgjqetuo Windows and Doors 2 12-30-2013 08:59 AM
repairing rotten trim and plywood above garage abacker Roofing/Siding 33 10-21-2013 01:57 PM
Vertical Plywood Installation Roofmaster417 Roofing/Siding 14 01-23-2013 11:18 PM
lay vinyl tile on patched holes in plywood charotte Flooring 5 10-25-2012 07:59 AM
CMU Block to Wood...how to seal?? Gladiatorx Building & Construction 0 08-04-2010 01:17 PM
