How To Use Tile Spacers - Flooring - DIY Chatroom Home Improvement Forum
Like Tree1Likes
  • 1 Post By paul100
Old 02-15-2019, 10:20 PM   #1
Rewards Points: 238
How to use tile spacers
I bought the rigid tile spacers...I hear that you should remove them after about 3p minutes but I was wondering how this is done without stepping on or disturbing the floor tiles. This is my first tiling project so take pity on me!
Sdiver2489 is offline   Reply With Quote
Old 02-15-2019, 10:45 PM   #2
Rewards Points: 112
Re: How to use tile spacers
Normally we just leave spacers in until the tiles are dry. never heard of them being removed so quickly.
Guap0_ likes this.
paul100 is offline   Reply With Quote
Old 02-15-2019, 10:50 PM   #3
Rewards Points: 238
Wouldn't the spacers stick to the thinset and be tough to remove or does the smooth plastic release from thinset easily?
Old 02-15-2019, 11:04 PM   #4
Rewards Points: 132
Usually they are put in sortof loose and not pushed into the thinset to tight. Yest, they smooth plastic should make them easier to remove. Sometimes you need the take a smooth flat screwdriver and pop them up before grout.
Ca443 is offline   Reply With Quote
Old 02-16-2019, 05:35 AM   #5
retired painter
Rewards Points: 560
Ya, the only reason I know of to remove them early is if you don't have enough for the entire job. I'll use my pocket knife to pry up any stubborn ones.
mark sr is online now   Reply With Quote
tile over tile aflemi01 Tiling, ceramics, marble 11 06-19-2015 02:03 PM
Tile over Tile ?? Piney Flooring 17 02-06-2012 09:59 PM
Tile over Painted Lightweight Cement New_2_DIY Flooring 16 08-28-2011 02:29 AM
Tile Grout Spacers zimmech Flooring 3 08-22-2011 08:20 PM
Preping for ceramic tile install leroyme Flooring 21 11-29-2007 03:31 PM
