How To Transition From Hardwood Stair Tread To Landing - Flooring - DIY Chatroom Home Improvement Forum
Old 02-04-2016, 05:16 PM   #1
211
Rewards Points: 49
how to transition from hardwood stair tread to landing
Im in the process of tearing out the carpet on my stairs and replacing with either a hardwood stair tread and riser kit or laminate with laminate stair moulding.
The kit seems like less fuss and a tidier, more durable solution, but each tread is thick. What am I supposed to do when I get to the top of the stairs? Im planning on continuing the laminate in the upstairs as well.
Basically by adding to each stair it leaves that last step to the landing shorter than the rest. How do I solve for this?
211 is offline   Reply With Quote
Old 02-04-2016, 06:21 PM   #2
Ole Wood Worker
BigJim's Avatar
Rewards Points: 588
It also makes your first step 3/4 inch taller, all you can do is remove what is there now and replace it with something that is structural enough to support the weight a regular stairs does. Code says you can not have a rise more the 1/4 - 3/8 inch (depending what your inspector says) difference on any step or rise.
New members: Please consider adding your location to your profile.
Lawyers believe a man is innocent until proven broke.
If you do what you've always done, you'll get what you've always got.
http://www.woodworkingtalk.com/forum.php
Jim
BigJim is online now   Reply With Quote
Old 02-04-2016, 07:19 PM   #3
Rewards Points: 18,354
Way to little info.
Riser "kit" tells us nothing.
No way would anyone be using laminate for treads or on a second floor.
This have been discused on this an any DIY site many times.
Real wood treads, landing tread at the top of the stair's and engineered 3/4" flooring is a far better way to go.
Hardwood stair tread trim or part of tread? Slammed01 Flooring 37 09-29-2014 06:25 PM
Hardwood floor open tread landing -- how should this look? Dave88LX Flooring 11 08-08-2014 11:00 AM
Question regarding gap between stair tread and skirt Awachter Carpentry 8 09-21-2012 10:06 AM
Carpet upstairs with hardwood stairs ... what to do with top stair? jmai14 Flooring 3 09-10-2011 09:57 PM
Hardwood and Tile Transition Gap mobowhunter Flooring 2 01-19-2008 06:25 PM
