How To Select Carpet With Pad For Finishing Attic Project? - Flooring - DIY Chatroom Home Improvement Forum
Old 08-04-2014, 01:30 AM   #1
Rewards Points: 31
How to select carpet with pad for finishing attic project?
I have received two estimates. One estimate has 27 ounce carpet with 7lb pad while another estimate has Essay-1 35 ounce with 6# pad for attic flooring. Do you think Essay-1 35 ounce with 6# pad is good enough for the attic flooring over the car garage? I want good insulation in the attic. Thank you for your answer.
compiler is offline   Reply With Quote
Old 08-04-2014, 01:02 PM   #2
Pro Flooring Installer
rusty baker's Avatar
Rewards Points: 398
Rather than being concerned with insulation, I would want the pad that should go with the carpet you are buying. Different carpets need different pads for long life and wear. See what the mill says to use.
The ads in my post are there without my permission. I do not endorse any of the products.
Semi-Retired Installer
Installing since 1973
Tags
carpet for attic
Carpet in the basement Packer Backer Flooring 17 11-30-2018 03:10 AM
Nominations For August 2014 DIY Project of the Month Cricket General DIY Discussions 32 08-07-2014 09:29 AM
Attic insulation simagic Insulation 1 05-07-2014 01:06 AM
Carpet Flooding and Replacement airjay81 Flooring 1 05-08-2012 01:00 PM
Insulation in the attic when the furnace is up there Jimmybrp Insulation 2 12-11-2011 03:26 PM
