How To Replace Threshold - Flooring - Page 2 - DIY Chatroom Home Improvement Forum
Old 09-21-2013, 04:29 PM   #16
Rewards Points: 590
I got a piece of trim and of course its to thick and I don't have a table saw. Would a planer work?
nikeman is offline   Reply With Quote
Old 09-21-2013, 08:39 PM   #17
Rewards Points: 18,376
You've been in the medical field to long, take imperial measurement when you go.
Old 09-22-2013, 09:33 AM   #18
Rewards Points: 590
I took the old trim with me and I knew the height difference was 10mm. The guy at Lockwood suggested the table saw method just like you guys. I have a power plainer but maybe this can be an excuse to buy a portable table saw.
Old 09-24-2013, 12:00 PM   #19
Rewards Points: 1,042
A planer will work,a little dicey though.
Canarywood1 is offline   Reply With Quote
Old 09-25-2013, 10:59 AM   #20
Check if it helps you: how to replace threshold
eliciasam1 is offline   Reply With Quote
Old 10-15-2013, 03:16 PM   #21
Rewards Points: 590
I got an old bench saw from my father in law. I think it needs a new blade and I am wondering if I need a certain type to cut this trim down some. I'm gonna look for a thinner blade and basically just trim off about the thickness of the blade which I think will be enough to make this trim sit flat on the wood and vinyl floors.
Old 10-16-2013, 02:25 PM   #22
You don't need a threshold, you need a reducer.
clayduster71 is offline   Reply With Quote
Old 10-16-2013, 04:32 PM   #23
I think he will be ok with a reducer
Rico_44 is offline   Reply With Quote
Old 10-16-2013, 05:44 PM   #24
Rewards Points: 590
What's a reducer?
Old 10-16-2013, 06:50 PM   #25
Rewards Points: 590
What I have is a reducer. I thought it was all one in the same.
Old 10-19-2013, 11:05 AM   #26
You need a reducer
A reducer looks like this:
It is used to take a floor from your level down to vinyl.
You could use a Threshold:
but the reducer would transition much better and not be as an abrupt step upwards.
FYI -- The reducer image I posted is a flush mount one for engineered/solid hardwood. The on you need for laminate will be a "over the top" fit.
Just my 2 cents.
Old 10-20-2013, 06:51 PM   #27
Rewards Points: 590
Here's my handy work. Not perfect but I'm happy with how it looks and feels on my foot when I step on it.
Old 10-20-2013, 08:39 PM   #28
Good Job
Good job!
Old 10-20-2013, 10:41 PM   #29
Thumbs up
job well done
you did a great job! as long as you like it that's all that matters. I do a lot of 1st timers and sometimes I take all my time until I convince myself that no matter how it comes out I can live with it, that makes me think a little harder working on the project.
you did great my DIY Chatroom friend!
rico_44
Entry door adjustable threshold JLars Carpentry 3 02-12-2013 11:07 AM
waterproofing under threshold bentnail Windows and Doors 3 10-07-2012 08:37 PM
Replace threshold? thaKing Windows and Doors 4 07-17-2012 12:27 PM
Should I chance removing this threshold? rosemonster Building & Construction 7 08-22-2010 10:34 PM
Replace door sill = Need new door? NNJGUY Carpentry 23 09-01-2009 02:54 PM
