How Much Height Does Adhesive Add? - Flooring - Page 2 - DIY Chatroom Home Improvement Forum
Old 05-12-2014, 04:16 PM   #16
JUSTA MEMBER
Rewards Points: 3,804
Joist hangers are the accepted way , plus screwing the new to the old, And it can be done throughout, but not needed anywhere except where the tile is.
Unless you want to get a waterbed, or some heavy appliances, furniture,a M I L.
ED
de-nagorg is offline   Reply With Quote
The Following User Says Thank You to de-nagorg For This Useful Post:
JazMan (05-12-2014)
Old 05-12-2014, 05:17 PM   #17
Rewards Points: 47
Whats an M I L?
Kaveman42 is offline   Reply With Quote
Old 05-12-2014, 05:48 PM   #18
Tileguy
JazMan's Avatar
Rewards Points: 802
MIL? Usually mother in law, but hopefully not this time.
Joists hangers screwed not nailed. Joists glued to the bottom of the subfloor. It's a very tedious process cuz you need even contact with the subfloor, otherwise you need to shim and that can cause big trouble. I would install "L" brackets to draw down the sub to the joists....carefully.
Jaz
MARBLE from ITALY & GREECE -PERLATO-PERLATINO-BOTTICINO-THASSOS-SIVEC-VOLAKAS-CALACATTA- NAXOS-Slabs-Tiles-Custom containers shipped to you - [email protected]
Old 05-12-2014, 10:06 PM   #19
Rewards Points: 47
How would I use the L brackets? I can't screw anything deeper than 1" in the subfloor. Would that be enough?
Old 05-12-2014, 10:15 PM   #20
Tileguy
JazMan's Avatar
Rewards Points: 802
That's it, you've got it. You should be able to go 1 1/4" actually. You've got 2 x 5/8" ply plus 1/4" CBU with another 1/16" or so of thin set under the CBU, plus the thickness of the bracket.
Jaz
ridge height calculation oxbow Building & Construction 19 01-14-2012 07:26 AM
bypass shower door height (Need more height!) KAdams4458 Kitchen & Bath Remodeling 14 10-30-2011 10:04 PM
floating laminate over old adhesive jbitt Flooring 3 09-27-2010 04:58 PM
Purchase Planipatch to cover the old adhesive ? jmpkiwi Flooring 1 02-11-2010 07:09 PM
Granite & Adhesive question cody21 Kitchen & Bath Remodeling 3 07-22-2009 05:11 PM
