How Long To Acclimatize Engineered Wood Flooring? - Flooring - DIY Chatroom Home Improvement Forum
Old 10-25-2017, 02:19 PM   #1
Endless Projects
Rewards Points: 1,350
How long to acclimatize engineered wood flooring?
I had changed my mind on my flooring choice. Instead of the bamboo I have been aging for years I just bought some engineered wood floors.
https://hallmarkfloors.com/portfolio...ron-chaparral/
I want to install this before Thanksgiving for family arrival. Is there any reason to let it acclimatize for more than a week? For a room over the unheated garage, would nailing or gluing be best?
Photobug is offline   Reply With Quote
Old 10-25-2017, 03:04 PM   #2
Naildriver
chandler48's Avatar
Rewards Points: 4,160
Re: How long to acclimatize engineered wood flooring?
Usually 72 hours is sufficient acclimation time. As far as the installation how thick is it, is it tongue and groove, click lock?
Larry......
Half of Communications is Listening, and You can't Listen with your Mouth.
chandler48 is online now   Reply With Quote
Old 10-25-2017, 03:41 PM   #3
Idiot with tools
Rewards Points: 106
If you're on a wood subfloor...nails nails nails. I used to work for a builder and I would cringe when they glued down engineered to the wood subfloor. Good luck ever tearing that up without replacing the subfloor.
a912 is offline   Reply With Quote
Old 10-25-2017, 04:17 PM   #4
Endless Projects
I have decided to go nails for that very reason. I have some bamboo flooring I had purchased many years ago. It has had a bad reputation, and the company recommended I glue it down.
The thought of gluing it and running into problems down the road, made me choose to get this other wood and also nail it. If something goes wrong I want to be able to pull it up.
Found the instructions online. It looks like 18 or 20 gauge 1 1/2" cleats or staples are called for.
Old 10-25-2017, 05:17 PM   #5
Rewards Points: 1,468
The length of time to acclimate depends on the difference between the moisture percent it contains and the average moisture of the surrounding wooden material. Six percent is a common percent moisture for indoor wood materials. It could be the same as what other wood is in the area it will be exposed to and need very little or no acclimation at all.
I once repaired some dining chairs for a lady that lived in Louisiana and when she moved to a drier climate they fell apart.
Ready to paint the porch! Oil or latex? Leah Frances Painting 10 08-24-2015 02:59 PM
OSB Stronger than Plywood? Weathermaker01 Flooring 15 12-22-2012 09:06 AM
Laminate wood flooring on slab newb questions shark974 Flooring 3 11-11-2011 05:57 AM
Engineered hard wood flooring Chpperk Carpentry 2 06-29-2011 06:27 AM
Strange engineered wood flooring install in Philippines (pics) Flt_Simulation Flooring 7 10-05-2009 09:00 AM
