How To Level Floor Covered In Carpet Adhesive - Flooring - DIY Chatroom Home Improvement Forum
Old 02-12-2016, 10:47 PM   #1
Rewards Points: 16
How to level floor covered in carpet adhesive
I've got about 600 sq feet of flooring in my basement that is currently covered in glue down carpet tiles. I've removed a few of the tiles and I'm guessing a pressure sensitive glue was used. The glue is transparent and very tacky.
My floor is uneven, perhaps up to 3/8" in places. I want to flatten out the floor and install wall to wall carpet with padding. I have used self-leveling cement previously on other projects, but I had a clean subfloor to start with.
What would you guys recommend for getting the floor flat enough for the carpet installation. I'm concerned about the ability of an SLC to bond to the floor with the existing adhesive. The floor only needs to be flat. It does not need to be level.
cej22 is offline   Reply With Quote
Old 02-13-2016, 11:34 AM   #2
Rewards Points: 459
I'd start with a stripper and a hoe. Erm... adhesive stripper and a garden hoe (don't get the wrong idea, here )
Nick DIY is offline   Reply With Quote
Carpet advice: Big box stores, budget, pad quality, etc 211 Flooring 1 12-17-2015 04:06 PM
adhesive recommendation for carpet in lieu of tack strip at doorway pman6 Flooring 8 05-12-2015 09:31 PM
removing carpet adhesive before tiling ratherbefishing Flooring 1 01-11-2012 04:43 PM
Carpet over VCT w/ Cutback My Old House Flooring 6 01-25-2010 09:19 PM
