How To Lay Click Flooring (laminate, Vinyl, Etc) Under Angled Stairway Trim? - Flooring - DIY Chatroom Home Improvement Forum
Old 06-02-2020, 06:58 AM   #1
Rewards Points: 64
Question
How to lay click flooring (laminate, vinyl, etc) under angled stairway trim?
As the title says... I'm installing LVP in my basement, and I'm not quite sure the proper way to do this. Because of the angle I can't lift the plank up to get it to click in place.
My guess is that for something like this I should shave off the lip on the groove, cut a piece of vinyl that will just slide in from the side and glue it? Possibly address the small sliver along the stairway "trim" separately? This close to the stairway there will be zero foot traffic or anything else.
I'm sure there's an industry standard way to do this... what's the proper way?
How to lay click flooring (laminate, vinyl, etc) under angled stairway trim?-img_20200602_074515.jpg
MOA_Chaser is offline   Reply With Quote
Old 06-02-2020, 10:03 AM   #2
Hammered Thumb
Rewards Points: 2,156
Re: How to lay click flooring (laminate, vinyl, etc) under angled stairway trim?
If the stringer is structural, then the LVP should butt up to it with the proper gap, so you can still set the tongue at an angle and drop down. If it's a face cover only, you should undercut it and slide the LVP from the front of the stair under it (with the proper gap along the beadboard). Assume you have the proper laminate tools, like a pull bar or tapping block, in order to slide the LVP along when it is T&G locked.
Your bottom riser looks awful short compared to riser#2 unless it's the perspective.
3onthetree is offline   Reply With Quote
The Following User Says Thank You to 3onthetree For This Useful Post:
MOA_Chaser (06-02-2020)
Old 06-02-2020, 11:06 AM   #3
Rewards Points: 64
Wow, awesome, I don't know why I didn't think of that. I guess I just assumed it was structural. I went down and checked, and was able to slide a utility blade all the way down the length of the stringer so it can't be structural. That'll be nice and clean, thanks!
Tags
click vinyl flooring , staircase
