How Important Thickness Of Carpet Pad? - Flooring - DIY Chatroom Home Improvement Forum
Old 09-29-2011, 09:32 PM   #1
Rewards Points: 682
How important thickness of carpet pad?
I've read that for normal carpet, 1/2 inch thick padding is too much, it allows the carpet to break down sooner, that 7/16 or less is much better.
How important is this? Is thinner padding more expensive? And are there pros and cons, like 1/2 padding makes carpet softer?
darsunt is offline   Reply With Quote
Old 09-29-2011, 10:44 PM   #2
Rewards Points: 150
Its not important at all if you dont care about your carpets life span. Get the best pad you can afford you will be glad you did.
OhioHomeDoctor is offline   Reply With Quote
Old 09-29-2011, 10:46 PM   #3
Pro Flooring Installer
rusty baker's Avatar
Rewards Points: 398
Pounds of density is more important than thickness. I would suggest 8 lb.
The ads in my post are there without my permission. I do not endorse any of the products.
Semi-Retired Installer
Installing since 1973
rusty baker is online now   Reply With Quote
Wet carpet on basement floor wvphysics Flooring 2 12-05-2010 02:26 PM
Subfloor thickness under carpet Avramel Flooring 1 05-14-2009 02:26 PM
Grrrrrrrrrrrrrrrrrrrrrrrrrrrrrrrrr chetsy Off Topic 9 12-03-2008 07:41 AM
Gaps at baseboards after carpet install cometbus Flooring 9 10-01-2007 08:48 PM
