How To Fill An ~.5" Thick Grout Joint - Flooring - DIY Chatroom Home Improvement Forum
Old 06-27-2018, 02:23 PM   #1
Rewards Points: 2
Exclamation
How to fill an ~.5" thick grout joint
Hi Everyone,
I have a condo build in 1946, complete with yellow and black vintage tile. The shower has a recessed soap dish and I currently need some advice on fixing the grout surround.
The soap dish does not have evenly spaced grout joints; the left side is a normal thin line that matches the rest of the tile work, but the right side is almost .5 inches wide! The grout is missing and needs to be filled. You can see the side of the soap dish as it is recessed into the wall.
I have NO idea how to fill that joint and then place grout over it. I'll add photos this evening or tomorrow AM. I can't get a tile guy out, the job is too small
Any help would be appreciated!
jne131 is offline   Reply With Quote
Old 06-27-2018, 02:32 PM   #2
Remodel and New Build GC
MTN REMODEL LLC's Avatar
Rewards Points: 2,264
Re: How to fill an ~.5" thick grout joint
Originally Posted by jne131 View Post
Hi Everyone,
I'd try cleaning it out and packing it with relatively dry sanded grout. I think you'll get away with it..... grout now has pretty little shrinkage.
(Let me guess at what probably happened... the original tiler did not install a corner soap dish before tiling and just left what he thought was room to install later.... doesn't fit in a corner.... don't ask me how i guessed...)
MTN REMODEL LLC is online now   Reply With Quote
Tags
grout caulk shower tile , shower tile , tile
Crumbling Grout Whyjune1st Tiling, ceramics, marble 0 04-03-2018 08:44 PM
Removing grout from top of ceramic tiles markdrum1 Tiling, ceramics, marble 3 09-28-2010 09:38 AM
Joint compound to smooth old paint layers. gmhut Painting 1 05-03-2009 05:50 PM
What works and what doesn't to clean grout? groutresearcher Flooring 2 09-04-2008 10:49 PM
is this bad tiling or am I being fusy??? rodger_j Flooring 23 07-16-2008 03:44 PM
