DIY Chatroom Home Improvement Forum (https://www.diychatroom.com/)
-   Flooring (https://www.diychatroom.com/f5/)
-   -   How do I get rid of smudges on porcelain tiles? (https://www.diychatroom.com/f5/how-do-i-get-rid-smudges-porcelain-tiles-203973/)
johnv713 07-22-2014 06:13 PM
I laid down porcelain tiles for my kitchen about 2 wks ago from and from the get go i noticed smudges. I tried porcelain cleaner that helps some but a few hours later the smudges come back. Probably foot print smudges. Please advise thanks.
cleveman 07-22-2014 08:51 PM
Pls. inform as to what the feet were in before they tracked on the tile.
johnv713 07-22-2014 10:27 PM
Earthlings...dogs..cats....but mostly Earthlings :)
oh'mike 07-23-2014 05:23 AM
Is the tile the problem or is there grout haze that is causing the smudges?
Have you tried vinegar?
johnv713 07-23-2014 01:25 PM
No i havent tried vinegar. I tried cleaner which did a great job until you walk on them again. I think it's the tile not the grout haze.
johnv713 07-23-2014 03:53 PM
I just used some vinegar, it turned out great except I got water stain now :(
Bud Cline 07-23-2014 04:22 PM
The tiles have open microscopic pores as a result of the firing process and likely a lower quality Porcelain. Clean them, then seal them several times.
johnv713 07-23-2014 05:42 PM
Oooh that's great to know. Some folks tell me to seal others said that's a NO NO.
Confused :(
oh'mike 07-23-2014 07:44 PM
Bud is an old pro---try his suggestion---do a sample section---
Bud Cline 07-23-2014 08:27 PM
John,
What (EXACTLY) is the name of the tile, what are they calling it? Word for word letter by letter.
johnv713 07-24-2014 12:29 AM
MS International Paradiso cream from HD. I did my whole kitchen, doorway entrance and 1.5 bath.
johnv713 07-24-2014 12:30 AM
Oh and theyre made in ...you've guessed it. CHINA!
Bud Cline 07-24-2014 07:59 AM
So where does it say Porcelain?
I think you may have fallen into a low-grade tile. It happens all of the time in the tile business.
If you will clean the tile and then seal it with a high quality "stone sealer" that may help. The trouble is...Once you begin sealing tiles, you have begun an ongoing maintenance issue you may have to continue from now on.
Ah-h-h-h-h, the Big Box Stores. Aren't they just the greatest thing?
johnv713 07-24-2014 10:06 AM
Darn it I was told they're porcelain. i got no choice tHere isn't much around here beside HD. Thanks!
Bud Cline 07-24-2014 10:58 AM
Porcelains have variations. There are variables used in the manufacturing process that can lower the cost of manufacturing so quess what. There is always someone around willing to take advantage of such things.
In the U.S. most all labeling of floor products as far as content, and warranty of merchantability for intended use, is voluntary, so it doesn't have to be totally honest all of the time. Leave it up to China and Home Depot to teach you the ropes.
I'll let everyone in on a little secret when it comes to purchasing Porcelain-ceramic tile. Porcelain is ceramic by-the-way.
To get around the labeling issues of selling a lessor-product, Porcelain tile makers and sellers play around with the names a little. For example you'll see tile sold under the name Porcelanato or Porcelanado. Sounds Italian doesn't it. You may also see Porcelaino and Porcelain Tina, also sounds exotic. The requirement is...If it is a "true Porcelain Tile" it must be labeled as such. When a manufacturer uses a variation of the word "Porcelain" then they have screwed with either the recipe or the manufacturing process so as to cheapen/lower their manufacturing costs.
So Buyer Beware.
This doesn't necessarily mean there is anything wrong with the lessor product other than the fact that it is "a lessor product" in some form. It all has to do with profit margins.
Generally when someone is experiencing what John is reporting, this more than likely means that the recipe has been abbreviated in some manner and the firing time in the kiln has also been abbreviated to reduce costs. This in turn generally creates microscopic pores in the surface of the tiles. When this is the case the tiles can be easily stained from the grout installation and can easily retain smudges and foot prints.
Therefore, the easiest way to deal with the problem is to seal those pores with something. Regular grout-sealers are vapor transmissive and therefore may not solve the issue in total. That's why I suggest using a stone sealer or enhancer that is topical in nature and after a few applications will close the pores and make the tiles less susceptible to holding dirt and make them easier to clean.
The downside is the topical products will likely change the appearance of the tile slightly and will create a future need to do it again when the topical sealer wears away. It is also likely that the sealer will cause a gloss that may not be desirable.
Topical applications will also have an effect on the original "Coefficient-of Friction" (COF) value of the tile. I'm not going to get into that.:)
Powered by vBulletin® Version 3.8.8
Copyright ©2000 - 2020, vBulletin Solutions, Inc.
User Alert System provided by Advanced User Tagging (Pro) - vBulletin Mods & Addons Copyright © 2020 DragonByte Technologies Ltd.
vBulletin Security provided by vBSecurity v2.2.2 (Pro) - vBulletin Mods & Addons Copyright © 2020 DragonByte Technologies Ltd.
