How To Cut Tile? - Flooring - DIY Chatroom Home Improvement Forum
Old 01-14-2015, 10:42 PM   #1
Rewards Points: 2,965
How to cut tile?
I have to cut about 5 porcelain floor tiles. My tile cutter is only 16 inches and these are 18 inch tiles. Is there another way to make long straight cuts without a tile cutter or a diamond blade?
mathmonger is online now   Reply With Quote
Old 01-14-2015, 10:45 PM   #2
Pro Flooring Installer
rusty baker's Avatar
Rewards Points: 396
Side grinder.
The ads in my post are there without my permission. I do not endorse any of the products.
Semi-Retired Installer
Installing since 1973
Old 01-14-2015, 10:54 PM   #3
I didn't try that, but I'm assuming I'd have to use an expensive diamond disc. No?
Old 01-14-2015, 11:37 PM   #4
Tileguy
Bud Cline's Avatar
Rewards Points: 558
Diamond blades aren't that expensive.
You could mark the tiles and take them to Home Depot to be cut maybe. Some stores do it, some don't.
XXX
Old 01-15-2015, 08:48 AM   #5
Rewards Points: 144
Just bought a new diamond blade the other day for my angle grinder to cut porcelain tile.$21.00 at HD
mako1 is offline   Reply With Quote
Old 01-15-2015, 09:36 AM   #6
Rewards Points: 224
Cut 16" on one end, flip and cut the other 2" from the other side?
landman650 is offline   Reply With Quote
Old 01-15-2015, 11:59 AM   #7
Tileguy
JazMan's Avatar
Rewards Points: 780
No. An 18" tile will not fit into a 16" space. Cutters have bars/frames that restrict what you put within it.
Jaz
MARBLE from ITALY & GREECE -PERLATO-PERLATINO-BOTTICINO-THASSOS-SIVEC-VOLAKAS-CALACATTA- NAXOS-Slabs-Tiles-Custom containers shipped to you - [email protected]
Old 01-15-2015, 12:51 PM   #8
Rewards Points: 144
If you do buy a diamond blade for your angle grinder do not get a continues rim blade.Those are for wet saws.
tile shower replacement with new tile Axhammer Remodeling 86 08-19-2013 08:22 AM
Solving discontinued tile issue timbo59 Flooring 14 10-03-2012 09:03 PM
Asbestos Removal, Porcelain Tile Installation jimbriam Flooring 15 01-30-2012 02:46 PM
Removing Tile Over Hardwood: Need Help With Kitchen/Bath Creelove Flooring 3 02-01-2011 07:03 AM
Preping for ceramic tile install leroyme Flooring 21 11-29-2007 04:31 PM
