How To Cut Back Existing Carpet - Flooring - DIY Chatroom Home Improvement Forum
Old 03-22-2014, 01:43 AM   #1
Rewards Points: 396
how to cut back existing carpet
I'd like to cut back some existing carpet to expand a built in book shelf (well, tear it down and rebuild it slightly bigger)
How do I make sure the carpet doesn't go sliding everywhere? Can I just put down staples in the carpet near where I want to bring out the book shelf to? Is there anything special I need to do with the type of staples?
MLMIB is offline   Reply With Quote
Old 03-22-2014, 10:31 AM   #2
Rewards Points: 150
Why not just set the bottom panel of the bookshelf on top of the carpet? Otherwise I would suggest using a matching threshold trim piece.
joemontana16 is offline   Reply With Quote
Old 03-25-2014, 12:11 PM   #3
I'd install the shelf right on the carpet
Edward.L is offline   Reply With Quote
Old 03-26-2014, 09:18 AM   #4
beverlyLynch's Avatar
That's right Edward.L
beverlyLynch is offline   Reply With Quote
Wet carpet from a frozen pipe thaKing Flooring 4 01-09-2014 12:42 PM
New Carpet over hardwood with existing baseboards denovo Flooring 2 04-23-2012 11:01 AM
Wet carpet on basement floor wvphysics Flooring 2 12-05-2010 02:26 PM
carpet to laminate transition 8roty Flooring 3 11-08-2010 07:41 AM
Grrrrrrrrrrrrrrrrrrrrrrrrrrrrrrrrr chetsy Off Topic 9 12-03-2008 07:41 AM
