Hide Nail Holes In Red Oak Treads - Flooring - DIY Chatroom Home Improvement Forum
Old 02-07-2014, 10:20 AM   #1
Rewards Points: 1,274
Hide nail holes in red oak treads
Hi
A contractor installed "retro-treads" (red oak) on my stairs. It looks nice
He used glue and 16gauge nails, and left everything raw as we agreed I will stain the treads myself
I did a test on a piece of oak. I've filled some holes with regular wood filler, let it dry and sand, then applied 1 coat of stain (Rustoleum)
Well, I find the spots with wood filler still noticeable....
Is there a better way to proceed, to make sure those spots are barely visible?
Should I use stained filler/putty and the matching stain?
Any specific tips ?
Thank you
french_guy is offline   Reply With Quote
Old 02-07-2014, 10:36 AM   #2
Rewards Points: 18,354
Try one of these.
http://www.minwax.com/wood-products/...-pencil#Colors
Near impossible to get an invisible filler, close is as good as it gets.
Old 02-07-2014, 11:03 AM   #3
So is it best to fill the holes 1st and then stain, or stain 1st and fill the holes after?
Knowing that I will apply several coats of polyurtehane (I was told 7 layers are recommended for stairs.....)
Old 02-07-2014, 11:13 AM   #4
Fill then stain.
The more coats of sealer the longer it's going to last.
Old 02-07-2014, 03:40 PM   #5
I was also looking at the Minwax wood putty that comes in different colors:
http://www.minwax.com/wood-products/...wax-wood-putty
But apparently it's a non-hardening putty, and not sandable....!!! Not sure I can use that
And for the pencils, they don't say if it's hardening or not
http://www.minwax.com/wood-products/...lendfil-pencil
Looks like the only recommended product is the stainable wood filler:
http://www.minwax.com/wood-products/...le-wood-filler
Coudl somebody who used some of these profucts give some opinions?
What to fill in large nail holes MangoMelon Drywall & Plaster 8 08-21-2013 04:20 PM
Dark over light...Do I need tinted primer? melissaandkris Painting 17 09-09-2011 11:43 AM
How to install granit treads and railing lsyrkin Tiling, ceramics, marble 0 05-08-2011 09:43 PM
How to install granit treads and railing lsyrkin Building & Construction 1 05-08-2011 08:06 PM
Series of holes in periphery of basement slab BalowskiJ Building & Construction 4 04-18-2011 02:49 PM
