Help! Wood Looking Tiles Being Laid In A Wrong Pattern! - Flooring - DIY Chatroom Home Improvement Forum
Old 01-08-2014, 10:02 AM   #1
Help! Wood looking tiles being laid in a wrong pattern!
Hi all,
My contractor laid my tiles in halves instead of what we agreed upon (1/3th or more random). He said since kitchen, which have totally different tiles and size, was laid in halves, it would look better if the living room tiles are laid the same way. Now I'm stuck at the point where, what should I do?? Rip these tiles and redo? I guess these tiles cannot be reuse anymore? Does it look bad to leave it halves like this? I don't have enough experience to make this judgement. Can someone give me an input? Thank you very much!
ps. Just for you to see the room pattern. It's basically 3 rectangular rooms and be hide the wall is the kitchen.
Help! Wood looking tiles being laid in a wrong pattern!-img_8602.jpg   Help! Wood looking tiles being laid in a wrong pattern!-img_8595.jpg   Help! Wood looking tiles being laid in a wrong pattern!-img_8600.jpg
tae763 is offline   Reply With Quote
Old 01-08-2014, 05:36 PM   #2
Anyone has any opinion on the tile pattern? Didn't mean to bump this, but it's kind of urgent. Thanks guys
Old 01-08-2014, 06:04 PM   #3
Rewards Points: 18,448
Was anything in writing as to how it should be laid?
It will match the way the other floor was laid so the only one that would notice is you I'd bet.
tae763 (01-09-2014)
Old 01-08-2014, 06:54 PM   #4
It was not written, but the agreement was made clear, and the GC acknowledged that the way it was laid was not what we agreed upon. The problem is not what we agreed, but what should I do? If halves look good? If not, I will tell them to change it.
Old 01-08-2014, 09:16 PM   #5
K&B Designer
Live_Oak's Avatar
What's the lippage look like? The subtle warpage of the tile is why the manufacturer recommends the 1/3 offset. Its usually less of an issue with that than 1/2. But of the slippage is slight, you may be OK with it. Slide a credit card flat to the tile and if the adjacent end/middle height differences are higher than the credit card, you may end up tripping on it and I'd want it redone.
Do it right from the beginning if you only want to do the job once. It'll be cheaper in the long term.
Live_Oak is offline   Reply With Quote
The Following User Says Thank You to Live_Oak For This Useful Post:
tae763 (01-09-2014)
Old 01-08-2014, 09:18 PM   #6
Thank you very much, Live_Oak. I will do that right away.
Old 01-09-2014, 05:44 AM   #7
Doer of Many Things
poppameth's Avatar
Rewards Points: 576
Personally, I'd make him pull it and do it as agreed. I've seen several jobs laid in halves like this and even if lippage isn't an issue, it just doesn't look as good. Wood patterns should be laid in 1/3 or a semi-random pattern close to 1/3 for best visual effect. Real wood comes random lengths and laying the tile semi-random gets you closer to that look.
Darkling Designs
poppameth is offline   Reply With Quote
The Following 2 Users Say Thank You to poppameth For This Useful Post:
oh'mike (01-09-2014), tae763 (01-09-2014)
Old 01-24-2014, 03:49 PM   #8
HEY! so. how did the credit card check go?
sooooo curious about this tile job. sounds so familiar.
tracey s is offline   Reply With Quote
Tiles that look like wood Tile guy Kevin Tiling, ceramics, marble 17 09-15-2016 01:27 PM
OSB Stronger than Plywood? Weathermaker01 Flooring 15 12-22-2012 09:06 AM
ICF vs. Wood Framed JackOfAllTrades Building & Construction 31 11-01-2011 03:14 PM
posted in wrong spot- cold air wood grates??? 4just1don HVAC 1 12-16-2008 12:50 PM
Do I need to replace a rotten sill plate met Carpentry 8 07-11-2008 09:14 AM
