Help Steamer Ruined Wood Floor - Flooring - DIY Chatroom Home Improvement Forum
Like Tree2Likes
  • 1 Post By de-nagorg
  • 1 Post By chandler48
Old 05-01-2018, 10:20 PM   #1
Rewards Points: 2
help steamer ruined wood floor
I just moved into my first home and used a swiffer bissle steamboost steamer mop on the wood floor.
The floor now looks like it has circular dents all throughout. I'm at a complete loss. I had spot tested an area but it didn't damage so I did the entire floor I guess the mop wasn't hot or I was going to slow. I'm extremely saddened, at first I was angry now I'm crying because I don't know what to do and if the floors can be fixed- it looks really really bad, ans it's basically every inch almost every plank looks like this...the apartment is only 325sq ft.
Any help on what I can do to fix this is appreciated. I'm literally hysterical I don't think I can look at this floor every day. I can't believe I ruined the floor trying to clean it.
khouse is offline   Reply With Quote
Old 05-01-2018, 10:50 PM   #2
JUSTA MEMBER
Rewards Points: 4,078
Re: help steamer ruined wood floor
Is this a solid wood flooring, or a thin laminate?
Looks like you might have blistered the plastic coating on a laminate, but it is hard to tell with just one small area picture.
ED
Nealtw likes this.
de-nagorg is offline   Reply With Quote
Old 05-02-2018, 04:57 AM   #3
Naildriver
chandler48's Avatar
Rewards Points: 4,314
We do need to know the type of flooring. Laminate will die when water is introduced. I would not use a steamer on hardwood floors of any kind. Wider shot pictures surely would help us. IMO, these look like chair leg impressions that may have been exacerbated by the introduction of moisture. I don't think the steamer did these holes, but I do think it made them pronounced.
Yodaman likes this.
Larry......
Half of Communications is Listening, and You can't Listen with your Mouth.
chandler48 is offline   Reply With Quote
Old 05-02-2018, 07:10 AM   #4
Rewards Points: 352
Those look like dents. High heels maybe? I can't see how those could have been caused by a steam mop.
Tymbo is offline   Reply With Quote
Old 05-02-2018, 08:25 AM   #5
Property Mgt/Maint
Rewards Points: 6,554
Well as a tenant, your first call should be to the landlord. Explain what you did. He may have some options for you. If it is true hardwood flooring, it could be sanded and refinished. Not a fun project while someone is living in the house. Or maybe its time for a few area rugs.
Yodaman is offline   Reply With Quote
Old 05-02-2018, 09:48 AM   #6
retired framer
Rewards Points: 20,674
Water or steam can be used to raise dents back to flat. these dents were there before the cleaning was done.
Sub floor thickness for new hard wood floor curiousmind Flooring 4 06-26-2017 01:10 PM
wood floor in basement question Master Brian Flooring 12 04-17-2016 06:55 PM
Builders - New development - can't have engineered wood on 2nd floor? unknown00 Flooring 1 05-14-2015 11:24 PM
Laminate or vinyl on a concrete basement floor? pjpjpjpj Flooring 36 09-03-2012 01:37 PM
problem: Water on wood floor during refinishing HouseMgr Flooring 2 08-15-2009 09:19 PM
