Help Removing Flooring - Flooring - DIY Chatroom Home Improvement Forum
Old 01-12-2014, 10:40 AM   #1
help removing flooring
I have about 500 sq ft of travertine floor to remove. It's on 1/4 in hardy backer and that's on 3/8 particle board that's over the sub floor. I need to remove this down to the sub floor to complete my nearly whole house tile job. What is the best method to remove this?
patrickb is offline   Reply With Quote
Old 01-12-2014, 10:59 AM   #2
Tileguy
JazMan's Avatar
Rewards Points: 750
There's no easy way, but I would start at a doorway and try to get under the particle board with demo bars (crow bars), one in each hand. You'll improvise as you go and figure it out. There's no one way.
Have help and wear the proper clothing and eye protection of course.
Got plans for the new floor yet? Hopefully a better plan than the way that floor was done.
Jaz
MARBLE from ITALY & GREECE -PERLATO-PERLATINO-BOTTICINO-THASSOS-SIVEC-VOLAKAS-CALACATTA- NAXOS-Slabs-Tiles-Custom containers shipped to you - [email protected]
Old 01-12-2014, 11:05 AM   #3
Yep, new plan is to get to the sub floor, 1/4 hardy backer and porcelain tile. I will be using thin set between sub floor and hardy backer, with a 1/4 trowel, and same between hardy backer and tile. I will be laying 18" tile so I know I have to butter the back of the tile as well. Any information would be great.
thank you
Patrick.
Old 01-12-2014, 11:08 AM   #4
Rewards Points: 896
no help here, but just curious. I thought Travertine tile looked nice, but I don't know anything about it.
Startingover is online now   Reply With Quote
Old 01-12-2014, 11:13 AM   #5
nice looks but not good as a floor, It pits out very bad and does not hold up to foot traffic. very porous.
The Following User Says Thank You to patrickb For This Useful Post:
Startingover (01-12-2014)
Old 01-12-2014, 11:25 AM   #6
Tileguy
JazMan's Avatar
Rewards Points: 750
Originally Posted by patrick
............with a 1/4 trowel, and same between hardy backer and tile. I will be laying 18" tile so I know I have to butter the back of the tile as well.
Where did you get that bad info?
Also check this out;
Jaz
The Following User Says Thank You to JazMan For This Useful Post:
JetSwet (01-12-2014)
Old 01-14-2014, 05:28 PM   #7
Rewards Points: 195
Pitting can be filled. Floors can be polished and resealed. Just saying.
To remove, I'd use demo hammer and remove the travertine. Then go for the hardibacker. I don't know if you can get both tile and backer without damaging the subfloor. Your call.
olzo55 is offline   Reply With Quote
asbestos in our ripped up flooring?? 6fthook Flooring 16 07-29-2011 11:06 PM
Konecto flooring LookoutRanch Flooring 23 03-08-2010 03:32 PM
Installing engineered flooring in the Philippines Flt_Simulation Flooring 15 07-21-2009 08:00 PM
Basement flooring options.. Tommy2 Flooring 9 02-14-2009 07:06 PM
no glue, no nails wood flooring - little help? reds_21 Flooring 2 02-13-2009 11:32 AM
