Help With Floor Transition From Wood To Tile Floor - Flooring - DIY Chatroom Home Improvement Forum
Old 01-05-2016, 05:21 PM   #1
Rewards Points: 4
help with floor transition from wood to tile floor
My living room has the original hardwood floors from when the house was built in the 1950s. We had a new tile flooring laid and it was set on top of 1/2" mold resistant board creating a total of approximately 3/4 inch of an elevation from the living room transitioning into the tile kitchen.
What would be my best option for that transition piece?
I want the floor to look how it should of course, and I don't want it to be a toe stubber
greatlakes is offline   Reply With Quote
Old 01-05-2016, 05:33 PM   #2
Rewards Points: 4
pictures
pics of the floor.
Old 01-05-2016, 08:20 PM   #3
Tileguy
JazMan's Avatar
Rewards Points: 780
We need a pic of how it ends at the side walls. No way to know how wide the transition can be.
Jaz
MARBLE from ITALY & GREECE -PERLATO-PERLATINO-BOTTICINO-THASSOS-SIVEC-VOLAKAS-CALACATTA- NAXOS-Slabs-Tiles-Custom containers shipped to you - [email protected]
Old 01-05-2016, 08:31 PM   #4
firehawkmph's Avatar
Rewards Points: 2,550
I had to machine some wood transition pieces a few years ago for an old 1800's home that I did a ton of work in. Tile wasn't involved. The wooden floors going from some rooms to another were off by an inch or more. I made thresholds out of Doug fir to go with the wood flooring that was there. They were about 6-7" wide if I remember right, in order to allow for the height transition with a nice gradual bevel. The width of the openings were around six feet. The bevel took up about half the width. The width corresponded to the wall thickness with trim between the rooms. Get some pics for Jazman.
Mike Hawkins
firehawkmph is offline   Reply With Quote
Old 01-05-2016, 08:42 PM   #5
Rewards Points: 4
update
addition photos that you requested. Thanks a lot for the quick reply! I will be able to reply back quickly as well.
Kinda wish It was the 1/4 cement board instead of the 1/2 but the 1/2 inch was chosen based on being stronger/less flexing opportunity and its about the same price as the 1/4"
help with floor transition from wood to tile floor-floor1.jpg   help with floor transition from wood to tile floor-floor2.jpg   help with floor transition from wood to tile floor-floor3.jpg
Old 01-05-2016, 09:30 PM   #6
Tileguy
JazMan's Avatar
Rewards Points: 780
Decide whether you want to go with wood to match or a marble to blend.
If wood, you can go over the hardwood. Bevel to within " and ramp to the tiles. Sand, stain apply finish.
If you go with marble. Remove the last two strips of flooring and have a piece of marble or granite bevelled as needed. Determine the combination layers of wood/concrete backer needed filler for threshold to come flush with tiles. May need to add a " shoe on front edge of marble.
In both cases leave an expansion gap to the tiles and caulk with the same color as grout.
Transition new base molding to finish.
Jaz
P.S. next time you should go with " cbu instead of " In some cases " is actually stronger in some respects. " is for floors.
Old 01-05-2016, 09:36 PM   #7
Rewards Points: 4
If using wood, do you have any pictures you can find that would show how the finished product could look?
Is it bad that we used the 1/2inch?
Old 01-05-2016, 10:12 PM   #8
Google "wooden threshold pics" , you'll see many different kinds.
Mike Hawkins
Old 01-05-2016, 10:21 PM   #9
Tileguy
JazMan's Avatar
Rewards Points: 780
It's not bad that you used " cbu, just not necessary unless you want the extra ".
Don't tell anyone but......I used to use more " Durock and Permabase than ". Back then Durock also came in 5/16" & Permabase in ⅜" too. Switched to Ditra in the late '90's and used that mostly afterwards.
http://gandsmarble.com/index_files/threholdsmenu.htm#
Something like this. 2nd row, middle two examples. You'll have a marble/granite shop make it you. It'll be 2 cm thick, ( Little over "), should be 4.5" wide.
Jaz
Need advice in fixing "contractor's" botched shower floor tile job toocheaptohire Tiling, ceramics, marble 6 04-19-2018 10:09 AM
Marble mosaic tile over kerdi in shower floor problem markolya Tiling, ceramics, marble 10 09-16-2014 09:22 AM
How to remove single 18" ceramic floor tile hkeiner Tiling, ceramics, marble 8 02-28-2013 10:56 AM
Tile to wood floor transition stupid48 Flooring 2 02-18-2013 12:31 PM
How to Prep wood floor for ceramic tile ? mgoose Flooring 8 08-16-2009 08:46 PM
