Help With Floor Transition Of Two Different Heights - Flooring - DIY Chatroom Home Improvement Forum
Old 12-29-2014, 08:49 PM   #1
Rewards Points: 191
help with floor transition of two different heights
have a tile floor merging with a hardwood floor.
there is a 1/4" height different which is not the issue. i just need a reducing threshold/transition.
the problem i have is the length of flooring is 11 1/2' long. All the transitions that i can find dont go longer than 7 1/2'.
what are suggestions? do i just put 2 together? im afraid of that looking cheap.
any input would be great.
rygar is offline   Reply With Quote
Old 12-29-2014, 08:58 PM   #2
Tileguy
JazMan's Avatar
Rewards Points: 780
You need to leave an expansion gap between the two floors, so either a "T" or baby threshold is the most likely choice. It kinda depends on which is higher too. You always have to piece anything that long unless you can make your own. Got pics including at least one of the ends?
Jaz
MARBLE from ITALY & GREECE -PERLATO-PERLATINO-BOTTICINO-THASSOS-SIVEC-VOLAKAS-CALACATTA- NAXOS-Slabs-Tiles-Custom containers shipped to you - [email protected]
Deck stairs // How do I fix varying riser heights Davebosox1967 Building & Construction 18 04-25-2014 04:31 PM
What are typical eave heights? AlexHouse Building & Construction 5 09-05-2012 11:01 AM
Ridge vent with two different ridge heights? tylernt Roofing/Siding 5 07-25-2012 08:50 AM
install heights for shower fixtures rtoni Plumbing 2 10-20-2010 09:49 PM
ceiling heights chowblower Building & Construction 2 07-05-2007 11:42 PM
