Help With Balcony Decking Problem - Flooring - Page 2 - DIY Chatroom Home Improvement Forum
Old 03-24-2015, 12:04 AM   #16
Rewards Points: 324
And the right hand one in last pic is http://www.battenandcradle.co.nz/pro...adle-exteriors
mgp roofing is offline   Reply With Quote
Old 05-08-2015, 07:10 PM   #17
Rewards Points: 2
I agree with the last poster the sleeper brackets are the best way to go. you should also have a pitch on the deck itself of 4 deg, pitching away from the house. you could have solved it before the rubber went down. now it will be more difficult or more expensive or both. you should always consult a local professional that has a good reputation with the building department of your local town. if not a building department recommendation make sure you are comfortable with your builder knowledge and ability. many claim to be builders and just swing a hammer and some don't even do that.
handeman67
HANDEMAN67 is offline   Reply With Quote
American Standard intermittent inducer problem with presssure switch warning no such user HVAC 5 12-26-2011 05:20 PM
75 year chimney leak problem mstanleyg Building & Construction 10 03-30-2010 12:38 PM
Stymied by window leakage problem. Matth3w General DIY Discussions 5 06-11-2008 06:26 PM
Post-Tension Slab Problem Advice/Help Mike McBride Building & Construction 2 01-09-2007 01:51 PM
wooden balcony in living room Lorac Building & Construction 1 07-24-2004 03:33 PM
