Has Anyone Used Rust-Oleum Oil-Based Polyurethane For Wood Floors? - Flooring - DIY Chatroom Home Improvement Forum
Old 05-18-2018, 09:05 PM   #1
Divideby0's Avatar
Rewards Points: 64
Has anyone used Rust-Oleum Oil-Based Polyurethane for wood floors?
I'm preparing to refinish my upstairs bedroom & closet floors (about 240sqft).
I've done a lot of testing with wood samples and trips to my local paint store. I concluded that Minwax Oil-based Semi-gloss Polyurethane gave me the results I wanted. (See Attached, right hand side of sample)
Today my local ReStore (a discount builder supply store run by Habitat for Humanity) posted a new shipment of "Rust-Oleum Oil-Based Polyurethane for Floors" in 5 gal buckets for $50 each. Buckets are new and unopened.
I've not seen Rust-Oleum poly in stores. Just their Varathane which is wicked-expensive. Perhaps its the same as THIS, but rebranded?
I am hesitant to drop my testing for a bargain, but $50/5 gal seems hard to pass up considering I plan on also refinishing my downstairs (650sqft rounded up) within the next year as well.
Is the Rust-Oleum a worthwhile bargain to jump on? Otherwise I'll just stick to what I've tested.
Has anyone used Rust-Oleum Oil-Based Polyurethane for wood floors?-img_20180518_213034.jpg
Divideby0 is offline   Reply With Quote
Old 05-19-2018, 05:22 AM   #2
retired painter
Rewards Points: 1,776
Re: Has anyone used Rust-Oleum Oil-Based Polyurethane for wood floors?
I've not used it but at that price I'd be willing to try. While some oil base polys preform better than others, they all out preform most water based polys. Any way to tell how old that poly is?
mark sr is offline   Reply With Quote
Old 05-19-2018, 07:49 AM   #3
Divideby0's Avatar
Rewards Points: 64
In my testing, the Oil-based polys performed way better than the water-based too.
ReStore is kinda like the Goodwilll™ of building supplies and get donations from other builder supply stores. They check everything and wouldn't sell it if it wasn't good. Often their stock gets diverted to their construction projects (I volunteer a few times a month). A few months ago, I got a great deal on a 5 Gal of SW primer. It needed some hearty mixing, but I've had no problems with it.
I'll check it out when they open later today. What's the shelf-life of an oil-based poly?
Old 05-19-2018, 08:20 AM   #4
retired painter
It depends on how it's been stored along with how it's formulated. I've had some that would go bad within a month after opening the can but I have had some last for years.
I'd shake the can to make sure it sounds/feels fluid and plan on straining the poly just to be safe.
Old 05-19-2018, 08:29 AM   #5
Divideby0's Avatar
Rewards Points: 64
Shake a 5gal? I'm not THAT strong!
These are brand new in unopened pails.
Has anyone used Rust-Oleum Oil-Based Polyurethane for wood floors?-32864637_1928417753859303_3149036907229347840_o.jpg
Old 05-19-2018, 08:41 AM   #6
retired painter
All you need to do is tip the bucket back and forth so you can tell if there is movement.
There is probably a way to determine when it was manufactured but I don't know ... probably some sort of code on the can.
Old 05-19-2018, 09:49 AM   #7
Rewards Points: 368
I would recommend a professional grade product as they'll hold up a lot better. My preferred oil based polyurethane is Bona Woodline. Like anything else, you get what you pay for.
Awoodfloorguy is offline   Reply With Quote
The Following User Says Thank You to Awoodfloorguy For This Useful Post:
Divideby0 (05-19-2018)
5 Ways to carry on your hardwood floor shining brightly John_smith Flooring 3 02-24-2009 11:56 AM
oil vs water poly batwoman Flooring 6 09-30-2008 10:00 PM
Hardwood Floor Painting Advice / Tips / Tricks? cherie Flooring 3 09-05-2008 09:52 PM
Flashing NoExperience Painting 13 09-04-2008 05:56 AM
Refinishing kitchen cabinets picabo13 Painting 3 08-07-2008 10:28 AM
