Has Anyone Used This Flooring? - Flooring - DIY Chatroom Home Improvement Forum
Old 01-25-2014, 09:52 PM   #1
Rewards Points: 242
has anyone used this flooring?
I'm redoing our Kitchen and also the living room, I plan on installing ceramic tile in the foyer and came across this tile a home builders store.
It looks good. Has anyone ever used this?
http://www.snapstone.com/
hvac instructor is offline   Reply With Quote
Old 01-25-2014, 11:06 PM   #2
Rewards Points: 18,382
Interesting.
Every review I've found on it is split 50/50. They ether hate it or love it.
Main complaint is tiles cracked in the box before installing and cracking within a year of installing.
Old 01-25-2014, 11:35 PM   #3
Rewards Points: 97
I haven't used Snapstone before, but I have used a similar product called Stilelock. It is/was a click-lock floating tile floor system (I think it has been discontinued- can't find it anymore). The only difference is that it had built-in grout on the tray. I didn't have to add any kind of grout-like material. It was very simple and was not that time consuming. The outcome was really nice and people couldn't tell it wasn't permanent regular tile. I used it in an entry way and our bathroom. I would use it or a similar product (like Snapstone) again. Just make sure you get any kind of installation kit that is offered for it. The one they had for the stilelock system had spacers, a block to use to get a tight fit and a bar to use for pieces in tight spots, like against a wall. Made installation a breeze. I will try to post a couple of pics tomorrow.
Centex2011 is offline   Reply With Quote
Old 01-26-2014, 08:11 AM   #4
Rewards Points: 242
Thanks joecaption and centex, I'm still up in the air on it. I was going to put down 1/4 concrete board and do it the old way. I have about a month until I get the kitchen done to decide.
Old 01-26-2014, 10:23 AM   #5
Jb1234's Avatar
Rewards Points: 87
I assume you're on a wood subfloor. I've read that Snapstone works fine on flat concrete slabs where there is no deflection. But it can fail on wood subfloors when the homeowner doesn't bring it up to the same deflection standards as regular tile. I think most of the failures are really installation error and they try to blame the product. I considered Snapstone for my house but didn't like any of the color/styles.
Jb1234 is offline   Reply With Quote
The Following User Says Thank You to Jb1234 For This Useful Post:
hvac instructor (01-26-2014)
Old 01-26-2014, 08:02 PM   #6
Rewards Points: 1,002
I would avoid it.
It isn't difficult or expensive to get good results with tile, even for a diy.
cleveman is offline   Reply With Quote
Old 01-28-2014, 06:51 PM   #7
Rewards Points: 242
Thanks all. I think i'm going to not use it and do it the normal way with hardiboard.
Installing Hardwood Flooring on Concrete Flooring, Condo slickwilly789 Flooring 4 06-07-2017 07:24 PM
How to Install Semi Solid Oak Flooring jastin123 Flooring 0 07-19-2012 12:51 AM
asbestos in our ripped up flooring?? 6fthook Flooring 16 07-30-2011 12:06 AM
Installing engineered flooring in the Philippines Flt_Simulation Flooring 15 07-21-2009 09:00 PM
